Results 1 to 1 of 1
Thread: ls1 build need advice
08-22-2008, 01:55 AM #1Junior Member
- Aug 2008
- fl
gray- 71 nova
in the process of my first ls1 build (have built a few motors in the past but nothing fuel injected) my goal is at least 500-550 rwhp through a six speed trans with natural aspiration, but with an eye towards adding a forced induction or nitrous system later if I feel the performance is lacking. my intentions are to use a fairly radical cam w/ upgraded lifters and spgs, port and flow heads, upgraded injectors, flat tops, hbeam rods, an aftermarket intake, arp (or similar) bolts throughout and a programmable "chip" system and a set of good headers w/ 3" exhaust. knowing that, what would you recommend for the build in the way of part brands, cam sizes, machine work, etc...anything you have tried or personally seen as effective or things i should avoid in looking to create a durable, driveable and powerful car that will run on premium pump fuel . this is going to be a driven street car, not a track or trailer queen (motor is a 2001 ls1, car is a 71 nova, , t56 six speed, 3:42 rear,cal-tracs traction system, gm 12 bolt, 4 wheel disc power brakes, 10 pt roll cage, frame ties, a/c, p/s, using rad from 96 t/a, this all has been done so far for mock up and fitment, now tearing down for paint and mods ) please include any and all info you have on any phase of this build you think will be helpful (clutches, trans, motor...whatever) and thanks in advance for the help
5.3 or 6.0 build advice
By blake864 in forum Internal EngineReplies: 2Last Post: 03-07-2016, 05:21 AM -
Help: Need build advice
By 1WickedWS6 in forum External EngineReplies: 3Last Post: 08-13-2012, 04:33 PM -
Build advice...
By ThunderChicken in forum General HelpReplies: 28Last Post: 12-16-2010, 04:21 PM -
350 build, need advice
By Poppn in forum Classic MuscleReplies: 5Last Post: 09-10-2008, 11:32 AM -
need some advice on build
By LS14Winter in forum Internal EngineReplies: 3Last Post: 10-13-2005, 01:35 PM
