Results 1 to 3 of 3
Thread: 5.3 or 6.0 build advice
02-27-2016, 09:08 AM #1Junior Member
- Feb 2016
- Greenville SC
Blue- 04 silverado Z71
Hey everybody, ive got a 4x4 99.5 silverado im building for occasional off road and fast too. Ive did alot of work on vehicles and enjoy it but building a motor is something ive never done but ive wanted to and nows my chance, my goal is to be around 450-500hp, I can buy a 5.3 under $1000 but im wondering if id have alot more in it than a 6.0 to reach my hp goal and things i need to do to get there, ive looked into diy turbo setups too (the fab parts isnt a problem) so im curious on opinions to that route too.
02-27-2016, 01:05 PM #2Spaz is My Mentor
Go for 6.0 liter block.
Much more potential.
Plus if later you can bore out make 403 or 408. Can use LS3 heads.
<<<<as a 6.0L block that is a 403ci.http://www.ls1.com/forums/f7/my-6-liter-build-174257/
6.0L Block - Forged 403ci
, Polluter Stg3 Cam, FAST 102mm Intake, NW102 TB, MSD wires, NGK TR6 plugs, Truck Coil Packs, LS3 Fuel Injectors, CC Pacesetter LT Headers, TS&P ORY, QTP e-Cutout, Magnaflow Muffler, 104mm Air Lid & Line Lock, Catch Can, Stage 2 T56 w/Viper shaft, PRO 5.0 Shifter, Tick MC, SPEC Stg3+ Clutch, QT SFI BH, MWC DSL, Full UMI Performance Suspension, Viking Coilovers, YR1 Snowflake Wheels wrapped in NT555 tires & Custom Fab Ford 8.8 rear w/Wavetrac Diff 3.93 Yukon Gears, WSQ Hood, 3"CM Strange Eng Drive Shaft.
03-07-2016, 05:21 AM #3
Here in IL the 5.3l are plentiful compared to the 6L. Both will take a ton of boost with very minimal aftermarket parts. Many of the guys build the 5.3l or even 4.8l around here because if it blows they can have another one the next day. It's really about how much you want to spend and how fast you want to go.
2002 Black WS6 A4.
FI, H/C, LT headers, full exhaust, Fast 90/90. MWC Fab 9". Subframe connectors,
Lower Control Arms, Panhard bar, Torque arm Strano Springs & Sway Bars.
Koni Yellows. FLT Stage VII trans w/ PAS3400
ASC# 4619 Conversion date was Dec 3, 2001
Help: Need build advice
By 1WickedWS6 in forum External EngineReplies: 3Last Post: 08-13-2012, 04:33 PM -
Build advice...
By ThunderChicken in forum General HelpReplies: 28Last Post: 12-16-2010, 04:21 PM -
350 build, need advice
By Poppn in forum Classic MuscleReplies: 5Last Post: 09-10-2008, 11:32 AM -
Question: ls1 build need advice
By cheappoolstuff in forum General HelpReplies: 0Last Post: 08-22-2008, 01:55 AM -
need some advice on build
By LS14Winter in forum Internal EngineReplies: 3Last Post: 10-13-2005, 01:35 PM
