Results 1 to 17 of 17
Thread: I NEED PART #'s
    Member screaminbird's Avatar
    Aug 2008
    Aurora, Illinois
    White/Gold
    99 T/A sold/67 Firebird
    I NEED PART #'s
    Ok so my cousin the one i bought my 1999 trans am m/6 from is being an ass and wont tell me anything done to internals or anything so far that i know of i have an LS7 Clutch,Short throw shifter,air lid,msd wires,hooker long tubes egr/delete,mandrel bend exhaust and no air pump i stole his dyno sheets from him and it had 383.57hp and 347.17ft-lbs at the wheels does this sound right with stock internals. Anyways now i need help with part #'s. To see if my MAF,Throttle Body, and Intake manifold are stock, please let me know asap if they are
    Intake Manifold-# 1 2 5 6 0 6 8 8
    Throttle Body- # 7 0 4 0
    MAF- # 8 9 8 7 1 9 1 4 5 7 5
    any help is appreciated also where is the part # on the heads can i get to it without dissambling alot of stuff
    Quote Originally Posted by screaminbird View Post
    Intake manifold is the LS1 intake, which is stock for 99 models.
    Painted manta stripe
    Aug 2008
    Aurora, Illinois
    White/Gold
    where would i find the head numbers and does that dyno sound right
    F-Body Genius Another WS6 Guy's Avatar
    Ft. Worth, Texas
    01 ECSB Z71 & 89 Iroc-Z
    With those mods, i seriously doubt it would make those numbers at the wheels. Knowing that a bone stock 02 SS A4 dyno'd at 296whp, i'd say the tock 99's put down around 280-290 at the wheels so intake/exhaust/egr delete/wires wouldn't make 100whp. Not even with a tune. It probably has a small cam like an LS1 hot cam or a ZO6 cam. That's my guess.
    Aug 2008
    Aurora, Illinois
    White/Gold
    how would i tell when i pull it out
    Ft. Worth, Texas
    the stock head number should be 12559853. And they are located either between number 1 and 2 underneath the valve cover or on the back of the head.
    Aug 2008
    Aurora, Illinois
    White/Gold
    so id have to take off the manifold and stuff, oor should i try taking off the valve covers first
    Ft. Worth, Texas
    I'd pull just the coil pack assembly and valve cover on one side (driver) and check in the rocker valley.
    Aug 2008
    Aurora, Illinois
    White/Gold
    sweet ill have to do that in the morning yah do you know if my maf and tb is stock the only reason i ask is because when i pulled it to clean it the gasket on it looked newer
    Ft. Worth, Texas
    The gasket is a rubber molding ring so it will always look newer. Like an orangish red color? Let me look around for the stock MAF and TB numbers, if I find them, I'll let you know.
    Aug 2008
    Aurora, Illinois
    White/Gold
    thankyou so much for the tips and info i appreciate it
    Ft. Worth, Texas
    25179711 STOCK LS1 MAF Part Number
    17113390 STOCK Throttle body for 98-99 F-body
    I don't know how you came out with a 4 digit number???
    Ft. Worth, Texas
    no problem. that's what we're here for.
    Aug 2008
    Aurora, Illinois
    White/Gold
    its right ontop of my tb
    so then is my maf aftermarket
    Ft. Worth, Texas
    I think the p/n on the tb is on the side of it? And I'd say the maf is aftermarket but I'd look all over it and make sure there's not a diff p/n on it.
    there is now a sticky thanks to Another WS6 Guy ...
    Ft. Worth, Texas
    Thank you, thank you.
  1. Help: T-Top peeps - need a part name or part number
    By NYKRINDFW in forum General Help
    Last Post: 08-02-2014, 07:30 PM
  2. Way to Go, ...Again, GM (Part 3)
    By wileyCoyote in forum Almost Anything Goes
    Last Post: 08-27-2011, 02:39 AM
  3. Help! I Need to find this part/part number!
    By BOILER_WS6 in forum Suspension and Handling
    Last Post: 10-25-2010, 11:10 AM
  4. Right part / wrong part
    By pajeff02 in forum General Help
    Last Post: 07-14-2009, 01:55 PM
  5. LSX part by part build
    By Sarge in forum General Help
    Last Post: 05-28-2007, 06:06 PM
