Results 1 to 18 of 18
10-10-2013, 06:27 AM #1
T-Top peeps - need a part name or part number
The end cap, weather stripping thingies on my T-Tops have melted and need to be replaced. I need a part name or part number to order a new set.
Any ideas what these are and where I can get them? Please see the attached pics !
Thanks!
NY
10-10-2013, 06:45 PM #211 years of bangin gears
- Jan 2009
- North Jersey
Check our sponsor GMPartsdirect. They should have it.
10-11-2013, 06:08 AM #3
10-11-2013, 07:17 AM #4COTM July '09
- Jun 2008
- Annapolis, MD
BLK/BLK w/CGM Stripes- 2010 Camaro 2SS/M6
Isn't that part glued onto the centrr bar? If so its possible you have to get the entire bar.
I like work. It fascinates me. I can sit and look at it for hours.
My Cardomain Site My Fquick site Custom Installs
10-11-2013, 07:43 AM #5
10-11-2013, 07:53 AM #6COTM July '09
- Jun 2008
- Annapolis, MD
The part you need is #14 (molding, T-TOP ROOF)
http://www.ebay.com/itm/2000-CAMARO-...5f01bc&vxp=mtrLast edited by Mean Green Z28; 10-11-2013 at 07:56 AM.
10-11-2013, 09:46 AM #7Senior Member
- May 2013
- Nashville, TN
Black / White- '00 T/A M6/'19 Hemi Truck
mine has been sticking out a little further than usual...im worried mine is getting ready to pop off like this one. Im assuming one that works for a camaro will also work for a TA?
10-11-2013, 10:37 AM #8
10-11-2013, 10:43 AM #9
12-27-2013, 01:44 PM #10
So I resolved this issue.
A parts manager at a Chevy dealership hooked me up.
First, he determined the part numbers, one PN for the front moulding and one for the rear:
Front: 10248550 "CAP-RF/WD" (for the front moulding)
Rear: 10248551
Once he determined the PN's, he ran a report from the nationwide database that spit out about a dozen dealerships around the country that showed them in stock and the quantity. He printed both reports out for me. I called one dealership near me that had the front moulding and a different dealership that had the rear moulding. With TTL & shipping, I spent about $25 for **two sets of each part...**one for this go round and another set for future repairs. They were delivered in about a week.
NY
12-27-2013, 02:04 PM #11Senior Member
- May 2013
- Nashville, TN
2000 Black TA M6 - LT's, ORY, UMI Short Stick, TT2's, Drilled/Slotted Rotors, Braided Lines, and Tuned by Vengeance
SCCA and Car Show Approved
06 Quad Cab HHHHemi - Sold
97 Camaro - Sold
12-28-2013, 07:14 AM #12
OK, now a new problem.
In order to install the mouldings the t-top bar between the t-tops has to be removed. I just removed the 8 screws and the bar won't budge.
NY
12-29-2013, 08:18 AM #13COTM July '09
- Jun 2008
- Annapolis, MD
It may have some sealant applied. Youll have to gently pry it u
01-10-2014, 06:25 PM #1411 years of bangin gears
- Jan 2009
- North Jersey
Either pry on it or cut the sealant with a razor blade, then pry it up. You could also use a rubber mallet to loosen it.
01-11-2014, 04:05 AM #15
you could try a cuttingwire (nylon) or something like that.
08-01-2014, 08:26 AM #16
So I finally got around to installing the new mouldings yesterday.
You guys were right, there is a plastic lining that runs under the length of the t-top bar. I had to use several wooden tongue depressors to get underneath it and pry it up. The plastic lining has a sticky adhesive on both sides of it.
Anyway, thanks again for your help LS1.com'ers!
NY
08-01-2014, 09:15 AM #1711 years of bangin gears
- Jan 2009
- North Jersey
Glad you fixed the problem.
08-02-2014, 07:30 PM #18
Help! I Need to find this part/part number!
By BOILER_WS6 in forum Suspension and HandlingReplies: 9Last Post: 10-25-2010, 11:10 AM -
Need Part Number Please
By Tickwomp in forum General HelpReplies: 10Last Post: 07-18-2009, 12:12 AM -
I need a part number.
By stephen02ws6 in forum Firebird / WS6Replies: 2Last Post: 07-31-2008, 03:42 PM -
looking for part number
By adham in forum General HelpReplies: 1Last Post: 03-02-2006, 06:31 PM -
Need Part Number
By Screamin Eagle in forum Appearance SectionReplies: 0Last Post: 02-23-2006, 10:58 PM
