Results 1 to 11 of 11
    Junior Member Tickwomp's Avatar
    Nov 2008
    Plano Texas
    2000 Z28 M6 Vert
    Need Part Number Please
    I picked up a LS6 intake for a great price, but need to pick up the coolant lines. Anyone have the part numbers?
    Thanks in advance!
    it's hard for me to read the numbers in the manual but this is what they look like to me
    plugs- 1256788
    front pipe-12568478
    rear bolts-11516425
    front bolts-12561089
    the numbers are kind of smudged looking but that looks right. Thunder racing carries the pipe and block off plugs.
    http://www.thunderracing.com/catalog...&sid=122#P3602
    Nov 2008
    Plano Texas
    2000 Z28 M6 Vert
    Thanks! I read that many folk simply plug the rears and go with the front crossover. Could one use another front in the rear?
    you can do that but the rear plugs are cheap.....I would do it right the first time.
    Nov 2008
    Plano Texas
    2000 Z28 M6 Vert
    Thanks! I definetely want to do this right!!
    This mod should hold me until I can save up for headers...
    Nov 2008
    Plano Texas
    2000 Z28 M6 Vert
    plugs- 1256788
    front pipe-12568478
    rear bolts-11516425
    GM parts numbers are:
    Coolant Plugs - 12602540
    coolant Gaskets - 12551933
    Front Coolant Pipe - 12602544
    Quote Originally Posted by Tickwomp View Post
    I have the parts manual cd's and those were the numbers it had on those......not sure why they're not correct buy you're right, the numbers I have arent' correct.
    Nov 2008
    Plano Texas
    2000 Z28 M6 Vert
    No problem, thanks for trying to help. I caught a break when I call Cheverolet parts. Dude answered in 2 rings and I described what I was trying to do, and he gave the numbers in less than 5 minutes. Oh yeah, and they had everything in stock!!! Looks like I'll be able to pull this off tomorrow after all. Even better, the weather here in Dallas is improving too.
    Senior Member
    Jacksonville, FL
    Don't know why GM changes part numbers all the time, maybe because of different suppliers or something? For example: If they haven't changed it again, the current PN for the 01-02 Fbody LS6 intake is 88894339 (formerly 88890524, 88890523 and 12561184 which came on my car).
    Member qwk93ta's Avatar
    Fairfield, Ohio
    00 WS6
    Quote Originally Posted by 2001NBMZ28 View Post
    88894339 is the part number for the LS6 I just bought off of Ebay.
    ls1 powered seabee sutie's Avatar
    oxnard, ca.
    red and black
    1999 Formula/WS6
    how many of the gaskets with p/n: 12551933 do i need for the swap. i just bought the crossover tube and the plugs,(X2). and what other gaskets do i need for the swap?
  1. Help: T-Top peeps - need a part name or part number
    By NYKRINDFW in forum General Help
    Last Post: 08-02-2014, 07:30 PM
  2. Help! I Need to find this part/part number!
    By BOILER_WS6 in forum Suspension and Handling
    Last Post: 10-25-2010, 11:10 AM
  3. Need a part number
    By bsteff in forum External Engine
    Last Post: 03-23-2010, 06:42 PM
  4. Need a part number!
    By patriot1136 in forum Firebird / WS6
    Last Post: 04-08-2009, 07:03 PM
  5. I need a part number.
    By stephen02ws6 in forum Firebird / WS6
    Last Post: 07-31-2008, 03:42 PM
