Results 1 to 17 of 17
Thread: subframe connectors???!!!
08-09-2008, 07:37 PM #1
i was looking to start the build of my t/a the safe way and install a set of frame connectors, but all the sets i looked at said they wont fit. does the car have these already? if so are there any other mods i should do before i start? i ultimately would like to have about HP. thanks for any advice.
08-09-2008, 09:47 PM #2
UMI makes a set for convertibles.
08-09-2008, 09:50 PM #3
start with an air lid
08-10-2008, 09:52 AM #4Member
- May 2006
- Canada
Blue 1997 Trans Am(Sold)- Pewter 2001 Trans Am Vert
BMR makes a set for us verts... they're pretty beefy I got there heavy STB aswell my car didn't have very much twist to begin with but I noticed a difference off the SFC's... well worth the cash!
08-10-2008, 04:23 PM #5
BMR.. makes a set, I installed them last year and they are well worth the money.
08-10-2008, 04:53 PM #6kthmc33
- Sep 2005
- Long Island
RED- 00 WS6
Stranoparts.com has both the 2 point and 3 point subframe connectors for convertibles
08-29-2008, 09:09 PM #7Junior Member
- Aug 2008
- nj
pewter- 2001 ws6
My go in next week
08-30-2008, 04:03 PM #8
09-04-2008, 10:03 PM #9
I have UMI and I like them a lot. I got the bolt ins, they didn't have weld ins back then but now they offer both. I'd get the weld ins if it were me. You can always get bolt ins and have them welded.
09-06-2008, 08:26 AM #10
03-22-2010, 07:52 PM #11
Hey - bump for an old thread...
Those with SFC's, what'd you do with the fuel line on the driver's side?
03-23-2010, 07:03 PM #12
I picked up the UMI part number 2027-B bolt in SFCs for my 2002. There was no interference with anything and no change to ground clearance. Clean easy install and they came with quality hardware. Very happy!!!!
03-23-2010, 07:11 PM #13Senior Member
- Oct 2008
- Coral Springs, Fl
hes got a goat
03-24-2010, 10:47 AM #14
03-24-2010, 04:37 PM #15
I had to assume since he is posting in the Vert section that he has more than the car listed on his avatar. I'm not sure if I'd like one of the new GTOs as a vert. I'm not terribly excited about the new Camaro as a vert either after seeing the spy shots.
03-24-2010, 07:41 PM #16
FWIW - I've got a '96 V6 'vert that I'm putting the UMI weld-in subframes on - though I'm temporarily bolting them in. Just noticed in a test-fit the fuel lines poking out that might keep the front end from lying up against the frame.
And no, I've spent enough on the Monaro conversion - so a convertible Monaro is out.
(Though I do like the lines... http://www.seriouswheels.com/cars/to...yn-Concept.htm)
05-12-2010, 07:25 PM #17
Bump for this thread - anyone ever get the "pop" on big one-wheel bumps after installing these? Sounds like something's loose at the right rear LCA bolt (but not the left), but I've already re-tightened it.
Subframe connectors
By cancam99ss in forum Camaro / SSReplies: 6Last Post: 07-20-2010, 03:45 PM -
Question: Umi Subframe connectors
By davidz28 in forum Suspension and HandlingReplies: 4Last Post: 05-15-2010, 08:45 AM -
subframe connectors
By Scanlamp in forum Rocky Mountain MembersReplies: 16Last Post: 06-20-2007, 07:25 PM -
i need help with subframe connectors
By 15T01Z28 in forum Suspension and HandlingReplies: 6Last Post: 06-12-2007, 03:25 AM -
Looking for subframe connectors....
By clg82 in forum Parts Wanted / TradeReplies: 2Last Post: 06-06-2007, 06:40 PM
