    yeah that's right! 15T01Z28's Avatar
    Feb 2007
    WPB, FL
    pewter
    '01 Z28
    i need help with subframe connectors
    i dont know much about subframe conn. i know the difference between bolt on and weld. im just not sure about different brands and styles. whats better?
    procharged,twin intercoolers,added fuel pump,larger injectors,kooks LTH+cats,slp loud mouth,strano springs/ koni shocks,ultraZ hood, spec stage 3+ clutch with flywheel, 130 LBS of weight reduction, swaybars, strut tower brace,3pt, sfc"yeah that's right"
    Member Frozen WS6's Avatar
    EagleRiver, Alaska
    RED, BLACK
    2001 WS6, 1998 TA
    I have SLP boltins. If I were to do some more serious racing I would also weld them in. But for street and some drag racing boltins work well. This is just from my experiances with daily drivers all the way up to a Nos'd ls1 that ran 10.90s in drag radials.
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    hmm 3 point SFCs are great. they do show a lil tho. um boxed are stronger then tubular. I'd sugguest weld-ons for several reasons. weld ons are more rigid then bolt ons. also bolt ons will eventally loose their purpose ..the more the 2 sub frames twist...the more the bolts will wear out the bolt holes ..so eventually they sfcs will be so loose they wont do their job. um SLP 3 point sfc are the best and you should get them..you wont be sorry, trust me
    Feb 2007
    WPB, FL
    pewter
    '01 Z28
    how would the ground clearence be for a car thats been lowered about 1 inch?
    Shepherd, Michigan
    98' trans am
    not bad. you'll loose about 1/2 - 1" max. just wait a few days hopefully. i will get mine on. on my first bird i really never payed attention to the clearance since i didnt drop the car.
    Member cobrahunter's Avatar
    South Bay
    1998 Camaro Z28
    I've got tubular Global West weld-on subframes. No problems with clearance - got Eiback Pro-kit on. With my side skirts, you don't even see them.
    fresno, ca
    deffinately go with weld on connectors if you weld, or know someone. bolt ons help but not nearly as much, they are more a way for us fabricators to make quantity sales since not everyone welds at home. get a nice weld on triangulated sub conn. with a drive shaft loop in the center to tie the entire belly together. now if only someone made one like that...
    wait a minute... i do! yay!!!
  1. Subframe connectors
    By cancam99ss in forum Camaro / SS
    Last Post: 07-20-2010, 03:45 PM
  2. Question: Umi Subframe connectors
    By davidz28 in forum Suspension and Handling
    Last Post: 05-15-2010, 08:45 AM
  3. subframe connectors???!!!
    By dadowd in forum Convertible
    Last Post: 05-12-2010, 07:25 PM
  4. subframe connectors
    By Scanlamp in forum Rocky Mountain Members
    Last Post: 06-20-2007, 07:25 PM
  5. Looking for subframe connectors....
    By clg82 in forum Parts Wanted / Trade
    Last Post: 06-06-2007, 06:40 PM
