Results 1 to 18 of 18
08-08-2008, 05:06 PM #1
Is there any common problems on the 98 z28?
I am looking to buy an LS1 f body and I see a lot of 98 z28s for sale. This is the first year of the LS1 in the F body and I was wondering are there any common problems or issues with the 98 models? Does anyone own a 98? Any major problems?
08-08-2008, 06:18 PM #2
I think the only big difference is the ECM computer. If you use a hand held programmer, it only works on the 98 models. Now the HP Tuners, LS1 Edit, EFI Live, ect... will work on all models including the 98. ( mine is all modded out now )
I've had no problems unique to the 98's... Good Luck !!!
08-08-2008, 06:39 PM #3
Theres not much of a huge diffrence between the 98s from the 99-02s, theres a few things but i havent heard of any specific problems to just the 98s
08-08-2008, 06:46 PM #4
Not specific to 98 years but all LS1' have VERY WEAK rear ends & if you get one with a Monsoon stereo the speakers are also very weak and of course they all have weak power window motors . Everything else about our cars is pretty much up to snuff I think .
08-08-2008, 07:39 PM #5
they are suspect to speeding tickets and reakless ops...lol
08-08-2008, 08:01 PM #6Desert Boat Guy
- Apr 2008
- Charlotte, NC
Black 2002 T/A M6- Green 1997 Ram 4x4
I've never heard of any problem specific to any year model, 98-02.
Only real differences you're going to find is that a 98 (and 99-00) won't have as good of an intake or clutch as an 01 or 02.
As for common problems. First off, pretty much everybody who's owned an LS1 f-body for more than 8 minutes has replaced a power window motor. And secondly, if you plan on doing any racing at all...upgrade that rear end. Stock power and sticky tires will snap it in a heartbeat.
Other than that...these are well built cars. Not much goes wrong with one if it's been taken care of. Even well past the 100k mile mark.
08-08-2008, 08:08 PM #7
they're the only year with temperature gauges that actually work. haha
08-09-2008, 05:57 PM #8
98's got perimeter bolt valve covers, thinner cylinder liners than 99-up and a couple of other things like a metal gas tank. When and if you go to mod it, you will find that aftermarket parts will be harder to find and sometimes more expensive. If you can, get a 99-up F-Body
08-09-2008, 05:58 PM #9
Here is a list of mostly all of the differences.
http://www.ls1.com/forums/showthread...3&goto=newpost
08-10-2008, 11:56 AM #10Junior Member
- Jul 2008
- va beach
black- 99 z28
the only problem i have heard of with these cars is the power window motors are weak on them and the iac getting gunky sumtimes causing a funny idle?
08-10-2008, 09:14 PM #11
I never had any problems with my 98-SS since I owned it new. 10-Years old and still have both my factory window motors with no problems also.
08-11-2008, 01:37 PM #12Junior Member
- Nov 2005
- Orlando,fl.
Black- 2001 Camaro SS
You'll need to make sure the oil pressure is good. Thats the only serious thing I have ever heard of. They dont flow very well in the 98's and alot of poeple get them ported or switch to a ls6 or aftermarket pump.
08-11-2008, 01:40 PM #13
08-11-2008, 02:37 PM #14Member
- Oct 2007
- CANFIELD, OHIO
PEWETER METALIC- 2002 CAMARO Z-28 M-6
08-11-2008, 03:51 PM #15
http://www.ls1tech.com/forums/showpo...80&postcount=2
that will show alot of differences
08-11-2008, 04:17 PM #16
08-11-2008, 04:30 PM #17
oh ok yeah some guys said they have used them but everytime ive searched all it brings up is hp tuners but oh well id rather do that anyway
08-11-2008, 05:10 PM #18
Common Problems of the T-56
By Knight in forum Manual TransmissionReplies: 25Last Post: 05-10-2016, 12:11 PM -
Common problems at 60k Miles?
By mammoth713 in forum Camaro / SSReplies: 14Last Post: 08-14-2010, 11:20 AM -
Common Code List - Problems and Solutions Here
By Hi-Po in forum General HelpReplies: 5Last Post: 01-26-2010, 09:12 AM -
cheap and easy home fixes for common problems..
By 0rion in forum General HelpReplies: 28Last Post: 06-23-2009, 05:07 PM -
Common Problems...
By F-body fan in forum General HelpReplies: 3Last Post: 05-01-2006, 05:53 PM
