Results 1 to 15 of 15
Thread: Common problems at 60k Miles?
08-06-2010, 11:32 AM #1
2000 Z28 M6
65,xxx MI
My car is going in the shop soon for some stuff.. mainly the check engine light came on randomly the other day. still idles fine, drives fine, same gas mileage, etc... no problems noticed other than this light being on.
Also, the coolant has a chocolate-milk-looking-crustyness on the coolant dipstick (posted in another thread about this), and i was told it might be oil in the coolant and that coolant needs to be flushed every 5 years..
What could the check engine light mean is wrong? Possibly an O2 Sensor? (already checked the gas cap, heard that could be it..)
i was just wondering what you guys typically fix around 60k or 70k miles..?
08-06-2010, 11:54 AM #2Junior Member
- Aug 2010
- British Columbia, Canada
Red- 2001 LS-1 Camaro SS
What I heard
Since the car has a computer....It is most likely programed to light up at whatever mileage G.M decides.....The dealer can turn off the light with the computer or a series of events......Hold button ? and tap brake pedal twice...etc
Regular maintenance is the best for any car.....My mechanic just keeps it running at peak performance. He has a computer and can turn of certain lights
but not all.......Ask questions at the dealership..........Maybe they will give you some straight answers.....But I doubt it.....
08-06-2010, 12:02 PM #3
Without getting a code, it's impossible to tell what the problem is. 100's of possibilities.
I think you are thinking of the change oil light. The SES light only illuminates when the computer detects something wrong with the emissions system. Such as a loose gas cap or evap system leak, faulty sensors, engine misfires, lean/rich...etc.
2018 Tahoe - Silver - OEM
08-07-2010, 01:39 AM #4
I cant realy think of anything that is a "typical fix" around that mileage, as long as you do routine maintence you should be good to go and like said above without the code its a shot in the wind. You said you checked your gas cap but did you "reset" the light afterwards? When your mechanic scans the codes post them up and we can help ya further.
08-07-2010, 06:08 AM #5
driving home yesterday, the check engine light went off...
hahaha
so i guess i wont know.
idk, i guess i'll have the shop do the coolant flush atleast, because that needs to be done
oh, what about transmission fluid? my buddy who has a 95 lt1 did his and he told me he read people use ATF in our transmissions?
is this true? When should M6 Transmission fluid be changed?
08-07-2010, 09:03 AM #6
08-08-2010, 09:47 AM #7Junior Member
- Aug 2010
Thanks Guys ...I am learning already.........
08-08-2010, 05:12 PM #8
08-08-2010, 07:10 PM #9
go over to autozone and have them go out with their scan tool and pull the code for you and give you a list of possible causes.
i just changed the trans fluid in my manual last summer (3000 miles ago at around 105k) and used dexron VI fluid since it calls for dex III (dex VI is the replacement for dex III).
08-08-2010, 07:13 PM #10Junior Member
- Jan 2010
- New Mexico
- 1999 Chevy Camaro z28
Your coolant is just the dex cool gettin nasty like it normally does lol just get it flushed and you will be ok!!!
08-11-2010, 09:50 AM #11
08-11-2010, 10:41 AM #12
Incorrect. This is the biggest misconception with Dexcool. The damage to the gasket is the result of not flushing your cooling system at the correct time/mileage intervals. Aluminum oxide sediment builds up and is what causes the gaskets to fail. Dexcool has a operating life of 5 years or 100k miles (whichever occurs first) and then needs to be changed. You'll be right as rain if you stick to the maintenance schedule.
08-12-2010, 06:10 PM #13
08-13-2010, 02:04 PM #14
The "check engine" could likely be an intermittent problem in the air pump. Mine went out at 36k and the dash light stays on. Not critical at all nor is it dangerous. Run your car by a parts house and have them run a code scanner on it, to be sure.
08-14-2010, 11:20 AM #15
I drained all my coolent at about 57,000 when I did heads/cam. Coolent looked fine and I put Dexcool back in. Never any problems.
Common Problems of the T-56
By Knight in forum Manual TransmissionReplies: 25Last Post: 05-10-2016, 12:11 PM -
Common Code List - Problems and Solutions Here
By Hi-Po in forum General HelpReplies: 5Last Post: 01-26-2010, 09:12 AM -
cheap and easy home fixes for common problems..
By 0rion in forum General HelpReplies: 28Last Post: 06-23-2009, 05:07 PM -
Is there any common problems on the 98 z28?
By importssuck in forum Camaro / SSReplies: 17Last Post: 08-11-2008, 05:10 PM -
Common Problems...
By F-body fan in forum General HelpReplies: 3Last Post: 05-01-2006, 05:53 PM
