Results 1 to 10 of 10
Thread: GTO clutch problems
08-08-2008, 07:26 AM #1
GTO clutch problems
Hi every1, just a quick Q: I hv a 2004 GTO. yesterday when I got in it went to push in the clutch and bang it broke, lucky me first my ignition than my locks now my clutch..My Q is, WTF, is goin on w my GTO. Is the car know 4 all these problems? Is it the clutch cable? Thx diemnzz
08-08-2008, 07:38 AM #2
08-08-2008, 08:03 AM #3
Definately need more info. Clear info, at that. "bang it broke" doesn't help.
08-09-2008, 11:28 AM #4
clear info
thx 4 replin, I got in my car went to push the clutch in and it made a sound like a hammer bangin on concret, than my clutch had no pressure to it. I love the car but the problems are more than its worth. I was told it might be a cable.!? could it be tht simple? Hv a awesome day!!!!
08-09-2008, 01:19 PM #5doesn'tplaywellwithothers
- Jan 2007
- Mayberry....(Indiana)
Black- 2004 GTO
Did you look 4 leaks?......is there a puddle under the car?.....did you check the resivour?.....do this and let me know.
Brad
08-12-2008, 07:27 AM #6
clutch prob..
I hv chk for leaks and there are none...nothing is wet in the engine nor is there any puddles under the car.. thx again 4 ure help greatly appreciated..
dcm
08-12-2008, 10:01 AM #7
You need to worm your head down there with a flash light and look at the pedal itself to see if it broke the top of the lever off.
Being that it is a hyd. system and you heard a solid bang I would lean toward that being the problem. Have you open the hood and checked the small master cylinder on the firewall for fluid level.
08-12-2008, 01:19 PM #8
When my throw out bearing went, I heard a 'POP' noise when I let out the clutch and then the clutch wouldn't engage. Not sure but maybe that could be it.
08-15-2008, 12:14 PM #9
found prob
THX again to evry1..I got down there n found the problem, the plastic piece tht connects to the pedal is snap off. GOOD thing its under warrenty and is being fixed..Hv a awesome weekend every1....
dawn
08-15-2008, 12:19 PM #10
Clutch Problems
By gameoverz28 in forum Manual TransmissionReplies: 2Last Post: 02-09-2010, 07:14 PM -
Had Clutch slave cyl, clutch master cyl, and Clutch kit installed now I got problems
By 7camaro7 in forum Manual TransmissionReplies: 21Last Post: 12-13-2007, 07:41 PM -
clutch problems please help
By adam0321 in forum General HelpReplies: 2Last Post: 04-12-2007, 12:39 PM -
clutch problems
By stoney2677 in forum Manual TransmissionReplies: 1Last Post: 01-29-2007, 01:31 PM
