Results 1 to 3 of 3
    i f*****g hate rice adam0321's Avatar
    north carolina
    1999 ws6 trans-am
    clutch problems please help
    i have a 99m6 ws6 I am having a problem with the clutch which just started a few days ago. it feels like the first 1-2 inches of travel have no resistance at all. the reamaining travel feels fine but the big problem is that the clutch is becoming stuck to the bottom of the floor. I have to pull it up and then push it down and pull it back up a few times after which the clutch will work fine for a few more rotations thrue the gears. it seems to stick more frequently when the car is driven hard. I have cheked the fluid and toped it off. I have been told that I may need to bleed the clutch, replace the slave cylender, and possibly replace the entire clutch. can you guys (and girls) please help me out with what you think this might be and what course of action to take, and if possibly could somebody give me the down and dirty has how exactly to bleed a clutch. I know the bleed valve is located near the bell housing, but that is about it, is it like bleeding brakes? Any coments would be greatly appreciated.
    thanks again
    adam
    Member SSpdDmon's Avatar
    Farmington, MI
    SOM
    '01 Camaro SS
    Sounds like the slave to me. There is little room for air to get into the system unless there's some kind of leak. How much did you have to top it off?
    Bleeding is straight forward - just need two people. Open top line, pedal down & hold, reconnect top line, pull pedal up. Repeat and top off fluid once more. At least, that's how we did mine.
    Are you sure the sticking pedal is not something silly like the floor mat getting in the way? Also, you might want to look into the master cylinder drill mod. There's a line connected to the master cylinder that has a restriction that should be drilled out for better flow.
    north carolina
    1999 ws6 trans-am
    i dont have floormatts so I know that is not it. I hardly put any fluid in the resevoir. mabe half a cup. can you tell me where exactly the master cylender is? thaks for the advice. I a afraid it might be the slave cylender.
  1. Clutch Problems
    By gameoverz28 in forum Manual Transmission
    Last Post: 02-09-2010, 07:14 PM
  2. Help: GTO clutch problems
    By diemnzz in forum GTO
    Last Post: 08-15-2008, 12:19 PM
  3. Replies: 21
    Last Post: 12-13-2007, 07:41 PM
  4. clutch problems
    By stoney2677 in forum Manual Transmission
    Last Post: 01-29-2007, 01:31 PM
