    Member Aetos's Avatar
    May 2008
    1999 Transam WS6
    steering wheel movement causes slight rpm drop?
    Tonight while going out I noticed if I'm sitting at idle and turn my steering wheel in any direction a bit my RPMs will drop by like 100-200.
    Car is 99 M6 with 45k miles. What could be causing this erratic rpm behavior?
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    Mine does it.. Power steering pump = parasitic drain...
    normal i do believe....
    mercersburg pa
    hugger orange
    2004
    dont know if it does it quiet that much but my goat does it too, Josiedoom has it right
    Beaver Dam KY
    79 T/A -91 Firebird
    Mine does it when its at hot idle. Cold idle it just changes the sound of the exhaust like its putting drag on the engine.
    Arizona
    Ya,,,years ago even on some carbed cars there was a power steering switch that would kick idle up when the pressure rised on the power steering pump,,,,don't know why GM got away from that but my guess would be gas consumption and meeting certain requirements. Every little bit helps I guess.
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    They do it in the PCM now, just like the A/C (which used to have the throttle bump noid too).
    It's in the tq mngmnt section (engine not trans!) and it plays into the frictional loss model. The IAC does step a bit to augment it, but I believe that it's a static offset at idle, which is why you see the droop.
    May 2008
    1999 Transam WS6
    Thank god, I thought I found another problem with my car
    on a side note my 02 sensors just arrived, yay.
    Arizona
    Thats good to know. I noticed it was in the tune for the A/C but didn't realize or see anything for the power steering.
  1. 99 firebird steering wheel movement
    By 08STiguy in forum Firebird / WS6
    Last Post: 03-23-2015, 10:02 PM
  2. 99 firebird steering wheel movement
    By 08STiguy in forum General Help
    Last Post: 03-20-2015, 09:22 AM
  3. Slight knocking sound from front left wheel ??>
    By 5abivt in forum General Help
    Last Post: 05-16-2009, 06:17 PM
  4. Steering Column movement?
    By squee in forum General Help
    Last Post: 12-01-2008, 08:55 PM
  5. Excessive Front Wheel Movement
    By T/Aboo in forum Suspension and Handling
    Last Post: 11-15-2006, 06:13 AM
