    Senior Member
    Toronto
    SOM
    2002 SS
    Slight knocking sound from front left wheel ??>
    Just noticed this after I did my brakes. a reminder I just swapped all 4 rotors and they were so siezed on I was whaling on the rotors with a hammer. the front left wheel now only over small bumps emits a slight knocking sound. Sounds like a dead strut or a ball joint not sure.
    any ideas?
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    Could be a worn wheel bearing or ball joint.
    old timer blue02Z's Avatar
    2002 Z28
    sell it
    jack it up and grab the tire top and bottom, try to move it back in forth if it moves watch your ball joints. if they are solid then it is prolly your wheel bearing. if you are on sure grab the tire at the 2 and 8 o'clock postions, if it still moves its most likely the wheel bearing
    Senior Member
    Toronto
    SOM
    2002 SS
    I will admit when I was smacking the rotor to get i off I did miss just a few times. I'll check it out when I install the new wheels/tires. i plan on going with new struts with the springs so that can eliminate that possibility.
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    Check the caliper brackets for tightness, check the slide pins for being able to move free, check for ball joint/tie rod end play. If you good there it sounds like a shock problem.. Im dealing with the same BS on a tired bird
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    did you tighten the wheel all the way?
  1. Slight knocking sound
    By silverWS6 in forum General Help
    Last Post: 04-30-2011, 06:30 PM
  2. Help: Knocking sound from rear end
    By PatrizioD in forum GTO
    Last Post: 04-10-2011, 10:31 AM
  3. Question: Knocking sound & burning a little oil
    By bull1112 in forum General Help
    Last Post: 05-17-2009, 05:46 PM
  4. Knocking sound with VID.
    By casperss in forum General Help
    Last Post: 09-10-2008, 04:26 PM
  5. Knocking T/A left side
    By Flutesailfish in forum Firebird / WS6
    Last Post: 04-15-2007, 11:48 AM
