07-27-2008, 01:19 PM #1Junior Member
- Jun 2008
- greenville, texas
black- 98 z28
HELP ME!!! 1998 Z installed headers no cats!!!
98 z28 with 90k, installed mac mid lengths, y pipe with no cats, 3 inch all the way back. Check eng light on, studders when accelerating, puts out a little smoke when swiches gears. I havent done anything to the pcm, someone told me that it could be running rich. What can I do without spending a fortune? Thanks in advance...
07-27-2008, 02:27 PM #2
Was the car fine before the header install??
Headers won't cause any of the aforementioned issues. You have one or more other problems at hand, most likely a direct result of the install of the headers.
Start with your plugs and wires, make sure you didn't crack any plugs and that they are all tight in the block. Pull the wires off and make sure there isn't any corrosion in them, and make sure they "snap" on to the plug once and onto the coil twice. Check the wires to see if any are touching the new headers.
Also check the headers and make sure you don't have any exhaust leaks where the headers meet the heads. Usually you can hear those kinds of leaks, it will sound like a Harley.
Be sure to re-check anything else you dissasembled or dissconnected to make sure things are properly hooked up. Get the code checked for free at your local Advance or Autozone, that will at least help you pinpoint the problem and give you a place to start looking.1998 Trans Am WS6 SGM
Lid, Pro 5.0, WS6 Short Stick, LS7 Clutch, TB Bypass, Detroit TrueTrac, Poly Mounts, Bilstein Shocks, LS6 Intake, SFCs, CTS-V Brake Upgrade, STB, Nitto 555's. SS Longtube Headers and True Duals w/ H pipe and Magnaflows. Tuned by Harris Speed Works. 341.4WHP/346.1 lb/ft.
07-27-2008, 04:56 PM #3
Also check for exhaust leaks around the header to y-pipe joints. Any leaks that let fresh air to the O2 sensors will cause an artificial lean reading.
07-27-2008, 05:16 PM #4
07-27-2008, 05:42 PM #5
The fact that its stuttering and smoking leads me to believe there is something else wrong besides being untuned.
I drove for 5 months untuned with my LT's and catless exhaust and never once did it stutter or hesitate. Might have had a couple small puffs of black smoke here or there but nothing very noticeable.
07-28-2008, 12:04 AM #6
sounds like possibly an O2 problem. Did you have to extend your O2 harness (not sure if you do on mid length headers) and if so did you make your own extensions or buy pre-made? Check your wires to the O2's and any other wires near the headers to make sure they're not melted, easy to do. Did you keep the air and egr? Check those connections for leaks. It really sounds like an O2 issue somewhere due to the install. Have those codes read. There will be codes due to no cats but I bet you'll find an extra 1 or 2 on there.
07-28-2008, 05:45 AM #7
07-29-2008, 09:05 AM #8
i have the same problem, i got a tune, and it went away for a little while and came back...im gonna check my 02 connections, and pulgs and wires tomm. and let yall know.
07-29-2008, 01:35 PM #9Junior Member
- May 2007
- Chas. WV 25303
WHITE- 2002 Z28
3" Exhaust
i am not a mechanic but i went down a similar road. i dropped a LS6 and used SLP HEADERS, cats, etc. it seems the exhaust was to cool to register properly with the O2 sensors. someone suggested CORVETTE O2s, but i ended up with a dyno that cured everything.
Installed KOOK headers no cats now it sounds raspy :-(
By Durango in forum General HelpReplies: 4Last Post: 04-14-2012, 06:19 AM -
Installed Random Technology Cats Y Pipe
By TerribleTed in forum External EngineReplies: 13Last Post: 12-30-2010, 05:32 AM -
Headers & ORY Installed
By SMWS6TA in forum External EngineReplies: 48Last Post: 09-28-2009, 03:25 PM -
Headers Installed!!!!!
By Y2KArcticSS in forum Camaro / SSReplies: 14Last Post: 08-14-2008, 06:38 AM -
who's installed their own headers?
By GottaHaveLS1 in forum External EngineReplies: 21Last Post: 08-12-2007, 06:11 AM
you should have had almost power surges and bogs... it's probabbly stuttering cause of the screwed up AF ratio and the 02 sensors reading like his cats took a shit on him... the smoke would be from him running rich...
