Results 1 to 2 of 2
Thread: Fuel pump problem
12-28-2005, 03:47 PM #1Hemi Destroyer
- Oct 2005
- Knoxvegas, Vol country Tennessee
Sebring Silver- 98 Z-28 camaro
Fuel pump problem
This is for a third gen camaro but should apply for the 4th gens as well, I recently installed a Walbro fuel pump for my LS1 conversion. Well tonight I plugged the ignition harness to the battery to test the pump and the clutch wiring, the pump wouldn't do anything. The car was a factory LG4 4bll 305 car but had both an electric in-tank pump and mechanical pump on the engine block. I hooked the new pump up just like it came out but it's not doing anything. I looked at the fuse panel to see if a fuse was blown but there isn't a fuse for the fuel pump. Where does this thing get power? If I could find the source then I could throw a multimeter to it and figure something out. Also, there is no gas in the tank but it should still come on. Is that pump ran by the computer? If it is then that's the problem because I removed the computer and ECM harness to install the LS1 painless harness. Thanks,
98-LS1
12-29-2005, 08:03 AM #2
The intank pump was a recall add on. It uses a seperate harness and has a dedicated fuse that should be mounted under the hood on the passenger side of the firewall.It has it's own plastic holder with two wires coming out of it. We did a lot of these recalls on cars with vapor lock.
Fuel pump fuel guage issues on my '02 B4C
By ANDYZ28 in forum Camaro / SSReplies: 7Last Post: 12-29-2014, 10:30 AM -
Pontiac Fuel Pumps - Do You Have The Right Fuel Pump?
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 03-15-2011, 09:20 PM -
Walbro 255 GSS341 intank fuel Pump problem
By John Junkins in forum General HelpReplies: 5Last Post: 02-18-2008, 01:44 AM -
Fuel Pump Problem!!
By M-Ten in forum General HelpReplies: 24Last Post: 12-04-2007, 08:38 AM -
Fuel Pump Pump Problem?????? Help!
By undertakersT/A in forum General HelpReplies: 4Last Post: 04-24-2006, 09:55 AM
