Results 1 to 20 of 25
Thread: Fuel Pump Problem!!
11-29-2007, 05:56 PM #1Senior Member
- Jun 2007
- St. Pete, Florida
Silver+Black/Black+Silver- 1999 TA M6/03 GSXR 600
Fuel Pump Problem!!
So today I was driving out of a parking lot when the rear end of the car started making an annoying whistling sound.. I didn't realize it was my car until about a mile or two down the road when it started getting louder.. It was driving me crazy because I couldn't figure out what it was..
So finally when I got home, I got out, and turned off the car and it stopped... So I turned it back on, and after listening for a good 10 minutes, I came to the conclusion that it was the fuel pump.
When I would turn the car to accessory, and the fuel pump started up like it normally does for a second or two, it would make that annoying whining sound again.
So after doing some research, I read that it's the bearings on the fuel pump that is whining, and there's some products you can put in your gas tank to lubricate them and eliminate the problem.. I'm praying that this is true and will fix the whine, because a new fuel pump is $399.
Is that true? And if so, what should I put in? Also is the car safe to drive until I can get what I need to put in tomorrow?
If anybody knows please help me out, it's driving me crazy and I would hate to spend $400 for a new fuel pump if I don't need it
thanks in advance
11-29-2007, 07:48 PM #2Awaiting Activation
- Sep 2007
- Colorado
Black- RIP S4 06Tbss
Well I dont want to tell ya but your fule pump is going out, that lube is prolly a temporary solution but that pump is going to just give up and leave you stranded on the side of the road and then you will have to pay for a tow....Been there done that....Get a new fule pump, and to break even worse news to you the fule pump doent cost that much compaired to the labor of putting it in ! But if you have to try the lube, I have never personally heard of it but ya never know
11-29-2007, 08:05 PM #3Senior Member
- Jun 2007
- St. Pete, Florida
yeah , i was thinking it might just act as a temporary fix but i'm not sure... If i DO have to replace the pump I just found some threads about granatelli/racetronix fuel pumps..
Apparently they're better and they're also $150-$200 cheaper than the stock ones.
I just wanna make sure I DO need a new pump and that the lube won't fix the problem on it's own.
11-29-2007, 08:53 PM #4
the job isn't that bad hopefully you don't have a full tank sometimes they will last a while after the whine its just a gamble do replace it asap I would go with a performance one rather than stock good luck
11-29-2007, 09:10 PM #5Senior Member
- Jun 2007
- St. Pete, Florida
lol thanks for that super long sentence
lol jk
yeah i'm just debating between the granatelli which is only like $125 or the racetronix which is around $225 i think, i think they both fit pretty easily right?
The cheapest fix for me in this area is probably the best, seeing as how i'm not doing any kind of FI, and IF i do decide to, it won't be until way down the road
11-29-2007, 11:29 PM #6M6 King
- Mar 2006
- WI
- Blog Entries
- 1
FP-60 from lube control works well for me. It's a fuel system cleaner/lube that really quited down my fuel pump. Mine was really loud with the back seat down and now I can't even hear it running.
11-30-2007, 03:12 AM #7
If you do have to change the fuel pump, you don't have to drop the tank. You can cut a whole in your back hatch area to get to it. Much cheaper on the labor cost. I had it done this way 4-5 five years ago with 0 problems.
11-30-2007, 06:22 AM #8
11-30-2007, 06:34 AM #9Junior Member
- Sep 2007
- Garnett,KS
you can put fuel additives in your fuel and it will help with lubercation but it will only be a temperary fix
11-30-2007, 07:40 AM #10
11-30-2007, 01:03 PM #11
I have a steel cover over the hole that is tack welded in place.
11-30-2007, 01:09 PM #12Senior Member
- Jun 2007
- St. Pete, Florida
it's under the carpeting right? not noticeable really?
12-01-2007, 07:27 AM #13
Yep, you'll never notice it.....
12-01-2007, 08:03 AM #14Senior Member
- Jun 2007
- St. Pete, Florida
well the last 3 times i drove the car, 2 times last night, and this morning.. the pump didn't make the noise at all! and it's the first time it's not made a noise sense it started making a noise ...
... lol i'm thinking maybe it will stop all together if i replace the fuel filter, maybe there's something clogging it that's making the pump work extra hard or something... i bought a new ac delco filter at advanced and i'm gonna put it in today, maybe the old filter is just extremely dirty.
12-01-2007, 09:08 AM #15
a dirty filter doesn't help but once the pump starts going out its a gamble you know its gonna go just don't know when
12-01-2007, 09:40 AM #16Senior Member
- Jun 2007
- St. Pete, Florida
yeah but it stopped the last 3 times i drove it, i'm gonna change the filter and put in some lucas ucl, i read that will fix the problem also, and see how it goes from there.. if i can get a few more months or more out of this pump without the whine i'll be very happy
12-03-2007, 07:27 AM #17Member
- Virgina
Black- 98 Trans Am
You probably heard by now that Marvel Mystery Oil is good too (as per ol' Sarge!).
12-03-2007, 09:57 AM #18Senior Member
- Jun 2007
- St. Pete, Florida
yeah he said that or the lucas ucl too.. i bought the lucas ucl yesterday and put it in, only filled up half a tank so i used half a bottle.. when i refill again i'll put in the rest.. still hasn't made the noise the last 3 days i've been driving.. so i hope it doesn't come back!
12-03-2007, 10:52 AM #19
I use the lucas fuel additive all the time, not for an ailing pump,,,but it's good practice for the fuel system in general.
I put a little in about every 4th or 5th fill up as regular maintainance on all the fuel injected cars we have. Been using that stuff for a few years with no complaints.
Although I don't think it's a fuel pump cure all. Eventually your pump may bite the dust. I personally would replace it before it leaves you stuck, usually in the most unpleasant situation,,,,lol.
I have always used Walbro pumps with good results.
For a piece of mind I would hook up a fuel pressure gauge to see what you have and make sure nothing funny is going on. You can pick them up at any parts store, plugs right into the fuel rail.
What I like to do is run a 4 foot hose and tape it to the windshield and go for a ride and see how it acts under a load,,,gives you alot of good info that way.
12-03-2007, 01:12 PM #20Senior Member
- Jun 2007
- Harrisburg, PA
Blackety Black- 35th Anniversary SS
Replacing the fuel filter won't help the pump since the fuel goes through the pump first. There is a strainer in the tank that you should replace when you replace your fuel pump. Some fuel pumps warranties will be voided if you don't replace the strainer at the same time.
IMO i would not cut a hole if the floor just to get to the top of the tank. If you do use a sawzall instead of a cutoff wheel because u'll throw sparks all over your interior. And don't cut in the wrong spot either. I dropped the tank in my 97 Z and it took me only a few hours to get it dropped swap the pump and put the tank back in.
I cut an access panel in my Isuzu trooper to get to the pump, it was almost impossible to use the same piece of metal to weld back into place. And when i was welding it back in there was a flash explosion under the truck because of the fuel vapors. Luckily i was in the truck welding but it burnt half of my dogs fur off and he ran away so fast he hit his head on the work bench and knocked himself out. I thought he was dead. Good Luck, don't get stranded that sucks.
Fuel pump fuel guage issues on my '02 B4C
By ANDYZ28 in forum Camaro / SSReplies: 7Last Post: 12-29-2014, 10:30 AM -
Pontiac Fuel Pumps - Do You Have The Right Fuel Pump?
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 03-15-2011, 09:20 PM -
Walbro 255 GSS341 intank fuel Pump problem
By John Junkins in forum General HelpReplies: 5Last Post: 02-18-2008, 01:44 AM -
Fuel Pump Pump Problem?????? Help!
By undertakersT/A in forum General HelpReplies: 4Last Post: 04-24-2006, 09:55 AM -
Fuel pump problem
By 98-LS1 in forum General HelpReplies: 1Last Post: 12-29-2005, 08:03 AM
