Thread: Wheel Stud Issue
07-18-2008, 04:18 PM #1
Wheel Stud Issue
I overtightened one of my lugs by accident (did not hear the click of the tq. wrench) and broke it. It was on the rear drivers side and was a PITA to fix. My advice if you need to replace a stud on this location is to take out the parking brake pin (which is held by a 10mm bolt) so you have a hole to tap the new stud with a punch (or similar item). You are also going to have to take the rotor off to see what you are doing.
I got my new stud from NAPA for $1.79 and needed to take a tiny amount off one side at the top so it would clear the parking brake "gear". The whole ordeal took a lot longer than I wanted it to (
), but if it ever happened again (I hope not!), I could do it in a fraction of the time.
07-18-2008, 07:32 PM #2O U 8 1 2
- Nov 1999
- over here...
how did you ge ta new stud in there with out pulling the axle???
07-18-2008, 07:36 PM #3Slow'er'Ass
- Thornton, CO
A stock size stud will fit without pulling the axle.
Or removing anything. Takes some time to find the right position, but there is one spot on the backing plate that will allow the stock size stud to be removed and put back in.
Remove wheel. Remove caliper. Remove rotor. Remove e-brake ring.
Hit dead stud with hammer until it pops out.
Turn the hub while trying to get the new stud through.
Now...try my 3.25" ARP studs.
Little different.
The piece the original poster removed (that is held on with a 10mm bolt) is the wheel speed sensor. This will make life much easier if you want to go that route. New stud can go into the hub via that hole.Last edited by Mr. Luos; 07-18-2008 at 07:42 PM.
07-19-2008, 07:47 AM #4
The piece the original poster removed (that is held on with a 10mm bolt) is the wheel speed sensor. This will make life much easier if you want to go that route. New stud can go into the hub via that hole.[/QUOTE]
So that's what that was!
07-20-2008, 09:22 AM #5Bone it like you own it
- Sep 2005
- TEXAS... U mad?
Black / Stryker Blue- 2K WS.6/ 2K9 G8GT
yup. like he said tho, 3.25"s are a whole different animal...
07-20-2008, 01:42 PM #6
yeah stock ones are cake easy to replace did all my rear ones in about 2 hours
Stock wheel stud size?
By Speed_kills_WS6 in forum Wheels and TiresReplies: 3Last Post: 08-01-2010, 07:19 PM -
Broken wheel stud
By stew215 in forum General HelpReplies: 6Last Post: 06-15-2010, 02:33 PM -
ARP 2.5 " wheel stud longer than stock ?
By 1sickSS in forum Wheels and TiresReplies: 3Last Post: 07-09-2007, 01:54 PM -
wheel stud length
By ntymd8r in forum General HelpReplies: 5Last Post: 07-05-2007, 07:43 PM -
Rear wheel stud removal...
By austinWS6 in forum Wheels and TiresReplies: 4Last Post: 12-31-2006, 06:30 PM
