    2002 WS6 Trans Am
    Rear wheel stud removal...
    I'm trying to replace wheel studs on the back of my 2002 Trans Am. It has traction control, so I'm having trouble getting the studs out. Will I have to remove the C clips on the axles in the pumpkin and pull the axles out a bit to do this or is there a trick?
    Are you replacing them with stock studs??
    If so...you can remove and install without removing the axles.
    If you are replacing them with longer studs...you will need to remove the axles.
    If you plan on doing it without removing the axles...you need to remove the caliper, the rotor, and the e-brake ring. Then you get to figure out the one place each stud can be removed and replaced.
    Arkansas
    99 Trans Am
    Yeah my buddy just had 3 replaced in his firehawk and the axles did NOT need to be removed just have to make sure the whole backend is off the ground and the car is in neutral until you find that sweet spot..
    2002 WS6 Trans Am
    I found the info on ls1tech.com...
    All you have to do is remove the traction control sensor, then there is a hole to pop them out from and to install the new ones.
    Thanks...
    Member ProwlerZ's Avatar
    Myrtle Beach
    2002 Z28
    BTW, in case it's not clear, the above comments on new studs without removing axels is only for stock size studs. Longer studs require the axels to be pulled out.
    She's baaaaaccccck...
    '02 Z/28 M6 Hardtop
  1. Help: Any rear wheel stud change tutorial here? need size also
    By torker in forum General Help
    Last Post: 11-29-2011, 08:43 AM
  2. Stock wheel stud size?
    By Speed_kills_WS6 in forum Wheels and Tires
    Last Post: 08-01-2010, 07:19 PM
  3. Broken wheel stud
    By stew215 in forum General Help
    Last Post: 06-15-2010, 02:33 PM
  4. Wheel Stud Issue
    By bspalmer in forum General Help
    Last Post: 07-20-2008, 01:42 PM
  5. wheel stud length
    By ntymd8r in forum General Help
    Last Post: 07-05-2007, 07:43 PM
