Results 1 to 13 of 13
Thread: Lt1 Engine Miss
07-17-2008, 06:26 AM #1Junior Member
- Jul 2008
- wi
red- 1996 PONTIAC TRANS AM
Lt1 Engine Miss
i have a 96 trans am lt1 with low power/ engine miss at low rpms. Seems to come and go. Engine light sometimes comes on while this is happening (always #7 cyl miss fire). #7 has a new plug and wire. I am planning on replacing the rest of the plugs and wires. I am wondering if the opti spark can also cause this. Any help would be appreciated.
07-17-2008, 11:59 PM #2Junior Member
- Jan 2008
- NJ
White with Black Stripe- 1995 Trans Am
I've got the exact same problem. Changed the coil and the icm to no avail.
I guess its the opti, really dont know
07-18-2008, 12:59 AM #3
If you've upgraded to fresh plugs and wires, and it's still showing a code for cyl #7, I would say more than likely it is your opti. Time to replace/upgrade.
08-06-2008, 11:44 AM #4
I had the same prob with mine. When you come to a light and sit a min it has a rough idle. When you start to go it is like it is starving for gas. I found the #7 plug wire was bad. it got up against the header and was burned. Replaced that and now it is fine.
08-07-2008, 10:45 AM #5LT1 Guy
- Nov 2006
- Va Beach
Quicksilver- 03 Corvette Z06
Before I jump to say its an opti problem you have a few more things to look at. Swap the #7 and #5 injector and see if the issue follows.
08-09-2008, 09:14 AM #6
opti. i have replaced mine 3 times in 30k miles. biggest joke ever. makes me sick
08-09-2008, 10:03 AM #7
08-09-2008, 10:34 AM #8
i understand that but i know two other lt1 owners same deal. 1 replaced 2 MSD optis in 30k.
08-09-2008, 10:54 AM #9
08-09-2008, 11:41 AM #10
08-11-2008, 05:10 AM #11Junior Member
- Jul 2008
- wi
opti spark, plugs, wires and water pump solved issue
08-11-2008, 11:54 AM #12
08-11-2008, 07:23 PM #13
a lot of people have trouble with MSD optis and go back to GM.
Help: 2002 LS1 engine surge/miss
By vonny in forum General HelpReplies: 12Last Post: 10-08-2010, 06:37 AM -
sudden engine miss
By ls1alltheway in forum General HelpReplies: 4Last Post: 03-14-2007, 06:17 PM -
95 fbird 3.4 engine miss
By toyzan in forum General HelpReplies: 2Last Post: 08-21-2005, 04:46 PM -
Possible Engine Miss
By Necction in forum General HelpReplies: 5Last Post: 08-16-2005, 03:43 PM
