Results 1 to 13 of 13
Thread: 2002 LS1 engine surge/miss
09-01-2010, 04:59 PM #1
Hello Again. I have a engine surge/miss problem. I first thought it was a bad tank of fuel, but after pumping it out and filling twice with fresh, its still acting up. There is no check engine light and what its doin is this- doesnt matter if its cold or warm, just off part throttle it starts holding back. I have a camaro with LS1, 6 speed, heads/cam/etc making 425RWHP. I can feel it acting sluggish, but still seems to go pretty good while acting this way. With a scan tool we cant see anything wrong...feels like a slight missfire. Its ok at just off idle (going up a gradual hill easily), but as soon as you push a little harder it starts to act sluggish again. I can hear it in the exhaust that there is something not right..and once in a while it will accelerate perfectly,,only to act up the next time. Im wondering if its an injector, slight head gasket leak, fuel pump failing, ?? Any Ideas. Also, I just installed new plugs and that wasnt it. The ceramic cones on the plugs had a shade of red on them, but looked to all be firing and were clean. If anyone has had this before, or any suggestions, please let me know what it was. Thanks.. Vonny
09-01-2010, 06:39 PM #2
How many miels on your car?
I had an issue like this on my Regal GS. Though not high performance like your car it acted the same way. When I replaced the fuel filter the car ran perfectly. I was clogged really bad. Changed it an problem solved.
09-02-2010, 04:26 AM #3O U 8 1 2
- Nov 1999
- over here...
could be a few things... first start off with some MAF cleaner... check your fuel pressure... when is the last time you changed your fuel filter??? if you have cats one might be clogged...
09-02-2010, 06:54 AM #4
Sounds like a MAF or cat problem to me. Cats can go bad and not trigger a SES light
09-03-2010, 06:13 AM #5
09-07-2010, 05:29 AM #6
I cleaned the Mass Air Sensor, and Fuel Filter was replaced. Same thing. Im gonna check fuel pressure and then onto the cats.
09-07-2010, 02:41 PM #7
Does it do it when the car is hot or cold or both?
Will it do it when it you first start the car up?
09-28-2010, 05:44 PM #8
Mines doing it too...Have you found the problem yet ???No cats on mine
10-07-2010, 10:52 AM #9
Fixed...After LOTS of testing and testing of different items, it was dirty Injectors. Had the Injectors professionally cleaned and it runs great. I think they may have been getting dirty for a while, man does it run good now. Thanks for all the replys!
10-07-2010, 02:15 PM #10
Do you mind I ask what it cost to have the injectors professionally cleaned and could any mechanic shop do it? Thanks
10-08-2010, 05:34 AM #11
I own a Car Dealership and should have brought it to my guys weeks before. I thought I would have been able to figure it out. They had it figured out in less than 1/2 hour. We have some sort of can that hooks directly to the fuel rail and it runs on the can. the can has serious cleaners in it. I would think that any good repair shop should be able to perform this. Good Luck. We charge around $100 to perform for customers. Takes roughly an hour.
10-08-2010, 06:16 AM #12Senior Member
- Apr 2008
- Madison, WI
^^^Yes we have the same fuel injection system cleaner setup at our shop and I've seen it cure dirty injector misfires and running issues many times. Its good stuff
10-08-2010, 06:37 AM #13
I was on the Hot Rod Power Tour (my 7th time), and got a bad tank of fuel in Iowa. I should have burned it through before parking it. It sat for about 3 weeks before I took it out again, and thats when the problems started.
Engine surge?
By Y2KBird in forum General HelpReplies: 13Last Post: 12-17-2011, 06:37 AM -
Help: Engine idle surge
By Adam_94_T/A in forum General HelpReplies: 0Last Post: 03-28-2010, 03:24 AM -
Help: Engine surge/flat spot 2k-3k rpm
By bcorwin in forum General HelpReplies: 16Last Post: 08-29-2009, 11:56 AM -
Help: Lt1 Engine Miss
By erik4816 in forum LT1Replies: 12Last Post: 08-11-2008, 07:23 PM
that is what happened to me...
