07-13-2008, 03:16 AM #1Member
- May 2008
- Formerly NYC. Strong Island now!!
White- 1999 Transam WS6
Borla exhaust, small quick question
I found a guy that is selling an LS1 borla adjustable system, but its currently on his LT1 trans am. The question is whether or not this system would bolt onto my ls1 car or was it modified to fit onto his lt1 car?
07-13-2008, 11:20 AM #2
Since they make a system for each engine, they were probably modified to make them fit. You will probably have to do some "unmodifying" to make the fit again for an LS1. Just my 2 cents! Good luck...the Borla's sound great.
07-14-2008, 07:11 PM #3
they make it for both the LT1 and LS1. the difference is where it connects to the y-pipe. the LS1 hooks right at the driveshaft tunnel. the LT1 hooks over under the passenger seat. everything else past the hook up point to the y-pipe is the same. you can modify it to fit your LS1.
07-15-2008, 02:55 PM #4Member
- May 2008
Thanks anyway, I ended up purchasing a system from a guy on ls1tech: Full borla adjustable system with a DMH electrical cutout on the adjustable plate. (wiring, switches, and all)
Borla Exhaust variations- question
By Ramairgod84 in forum General HelpReplies: 5Last Post: 10-26-2009, 12:15 PM -
Borla Exhaust Question
By 1TA LS1 in forum Firebird / WS6Replies: 34Last Post: 11-04-2007, 07:07 PM -
A quick question on exhaust
By AF1Strider in forum External EngineReplies: 6Last Post: 10-18-2007, 07:19 AM -
Quick exhaust question
By xxkazp3rxx in forum Camaro / SSReplies: 8Last Post: 04-27-2006, 08:26 AM -
By xxkazp3rxx in forum Firebird / WS6Replies: 3Last Post: 04-08-2006, 07:31 AM
