Results 1 to 20 of 35
Thread: Borla Exhaust Question
05-10-2007, 09:27 AM #1
Just had a Borla cat-back exhaust (Single tips) installed on my TA last night. It's much quieter than I expected. The guy at the exhaust shop told me to wait a couple of days and it should get louder, the computer has to adjust to the new exhaust and the muffler needs to break in. Is this true? Also, how much louder is the sound going to get?
Also, he used the clamps that came with the exhasut and put a small spot weld on each clamp. I wanted him to weld the pipes instead of using the clamps, but he told me using the claps are better. What do you think?
05-10-2007, 10:31 AM #2
I think you should have gone with slp loudmouth......mine is loud as shit and still sounds incredible, and not over priced like borla
05-10-2007, 10:37 AM #3
I don't like the tips on the SLP, plus I got the Borla's at a really good deal....
Does anyone have the cat-back borla system?
05-10-2007, 11:36 AM #4
05-10-2007, 11:58 AM #5
05-10-2007, 12:26 PM #6
05-10-2007, 12:32 PM #7
05-10-2007, 12:35 PM #8
- Feb 2007
- Bakersfield, CA
86 Buick Grand National- 02 WS6-M6 407 RWHP
Looks -your won't be able to see the clamps because they won't be there
05-10-2007, 12:40 PM #9
That’s the only reason, for looks. I wonder who is going to lie underneath my car to look to see if I have my pipes welded or if I used clamps. Unless I want to impress mechanics, I guess using the clamps are fine.
I was just worried about airflow using the clamps.
05-10-2007, 04:28 PM #10
05-10-2007, 06:58 PM #11
i dont have a catback only, but my catback is Borla... w/ longtubes, and high flow cats....its pretty damn loud
05-10-2007, 06:58 PM #12
o and its all clamped...no problems
05-11-2007, 07:46 AM #13
Wouldn't Borla consider that when they make their exhaust kits? - Borla told me they don't recommend welding their products due to the special notches they pre-cut on the pipe ends - This is where the clamps go. Also, the Million Mile warranty lets me sleep easier at nights.
However, traditionally I agree with your statement. Hypothetically, a good welding job should lower the possibility of an exhaust leak versus clamps. That’s why I was a little persistent about welding until I asked Borla.
As far as looks, I crawled underneath my car after work, and I have to say, it’s a pretty clean look with the clamps. I couldn’t see any of the bolts from the clamps. I’ll try to take some pictures this weekend
05-11-2007, 09:50 AM #14
- May 2007
- Columbia, MO
Medium Blue Metallic- 1999 Pontiac Trans Am
This is a little off topic, but am I the only person that thinks borla is the most ghetto exhaust system available? From all the pics it looks like the adjustability is from the single exhaust pipe before the muffler. If you put a plate with a smaller hole in it, then the exhaust flows through the muffler. If you take out the plate, the exhaust functions like a cutout and goes out the left pipe. So its like a variable cutout for $800? I know all you borla owners won't like that but is it not true?
05-11-2007, 11:22 AM #15
- Feb 2007
- Bakersfield, CA
Borla= about 500 dollars to much for an exhaust system
05-11-2007, 11:33 AM #16
- Pittsburgh, PA
you're buying a name brand with them. they've been in the biz for ever and can set their prices where they want-the value is percieved by the customer.
It's not ghetto at all, they are highly recommended systems, and yes, you can slide an e-cut out in place of the spacer and then have a fully adjustable system.
05-11-2007, 11:39 AM #17
The catback does need to get broken in for a few hundred miles, but after that, it should be pretty stable. I don't know about the computer adjustment though.
If the pipes were fitting fine and not moving much with the clamps on, you should be fine. I prefer welds because I'm a little insecure about leaks and bolts loosening and whatnot. I can't see clamps as ever being better then welds unless he was a bad welder or you forsee having to make adjustments to the exhaust at some point in the future.
EDIT: Got any pics of the car with the catback on? Borlas look hot.
05-11-2007, 01:13 PM #18
I did it at a custom exhaust shop which the welder had over 20 years of experience with welding exhausts. Originally, I had him scheduled to weld all the pipes, but once he looked at the clamps from borla, he stated that welding was not necessary because borla makes the best clamps and noches in the business - he worked for borla at one time. I called borla to confirm about using the clamps versus welding (I better not get any leaks or people will be hearing from one angry person).
Exhaust sounds freaking awesome above 4k RPMS. Sounds very clean and strong. And the tips are the best I've seen on any car. I'd say the quality for the tips alone is worth over $150. (IMO) (FYI: Round Dual tips)
As far as pics, I will probably have some after this weekend. Maybe a video too.....
05-11-2007, 01:16 PM #19
i think borla and Corsa are the two best catbacks out there, not ghetto, ghetto is SLP loudmouth and flowmaster. you pay for what you get
05-11-2007, 01:21 PM #20
I really didn't do the cat-back system for the HP gains..... However, I didn't notice a change in my horsepower. Feels the same. How much do you think I may have gained with the Borla? I was thinking about 5-7hp.
Difference between a cammed borla w full exhaust and stock borla
By third_shift|studios in forum Multimedia SectionReplies: 13Last Post: 02-06-2016, 02:27 AM -
Borla Exhaust variations- question
By Ramairgod84 in forum General HelpReplies: 5Last Post: 10-26-2009, 12:15 PM -
borla exhaust
By jaydean21849 in forum External EngineReplies: 3Last Post: 07-25-2009, 08:58 PM -
Borla exhaust, small quick question
By Aetos in forum External EngineReplies: 3Last Post: 07-15-2008, 02:55 PM -
***F-body Complete Catback Exhaust Borla Y-Pipe Flowmaster Muffler Borla Quad Tips***
By aztectt in forum Parts For Sale / TradeReplies: 0Last Post: 03-22-2007, 12:13 PM
