Results 1 to 2 of 2
Thread: 1st - 2nd Grind
07-12-2008, 01:10 PM #1Junior Member
- May 2008
- Buffalo, NY
1st - 2nd Grind
Hey guys
My car is a 98 Trans Am ws6 and is having issues with the 1st to 2nd shift at WOT. Basically, it'll either grind a little bit and go in, or it won't go in at all. During this time, the clutch pedal is all the way to the floor. When I'm driving it normally (shifting under 4k) there is no grinding to be found.
If I give it more time before I shift (let the RMPs fall a little bit, 2 seconds) it'll usually go in without a problem.
Does anyone have an idea what the problem could be? I've tried changing the transmission fluid to syncromesh, bleeding the hydraulics with new Dot 4 fluid, and put on a Pro 5.0 shifter to replace the stock one.
The clutch seems to be holding fine. I've tried revving it up high at a stop (with it in first) and it doesn't move at all.
The original owner replaced the clutch with a Centerforce II clutch so I'm not sure if that has anything to do with this.
Any suggestions are appreciated. Thanks
07-20-2008, 07:28 PM #2
Syncro...Its only gonna get worse.
5th gear grind
By LeadFarmer in forum Manual TransmissionReplies: 3Last Post: 01-24-2012, 07:16 PM -
why does it grind?
By TAallday in forum Manual TransmissionReplies: 8Last Post: 10-21-2011, 05:54 PM -
grind into 3rd
By mrmarcflo in forum Manual TransmissionReplies: 1Last Post: 04-27-2011, 08:50 AM -
Grind
By garver in forum Manual TransmissionReplies: 3Last Post: 10-16-2007, 03:43 PM -
1-2/2-3 grind
By Lextech1 in forum Manual TransmissionReplies: 10Last Post: 11-08-2005, 02:20 PM
