Thread: Grind
    oklahoma
    98 Trans Am Ws6
    Grind
    I press the clutch all of the way down, but the gears still grind. Is there any reason for this?
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Quote Originally Posted by garver View Post
    Does it do this at a stop?? How bad is the grind?? Can you get into gear at all??
    Depending on the severity of the grinding and when it occurs, it could be either the clutch or the synchros in the transmission. If it grinds at a stop and you can't get it into gear, its probably the clutch slave cylinder not disengaging the clutch all the way. If it happens when you are driving and generally when you shift quickly, it may be the synchros.
    oklahoma
    98 Trans Am Ws6
    Sometimes its bad sometimes it minor. It doesnt do it very often. It does it only when shifting into 3rd or 4th.
    NJ
    SGM
    1998 Trans Am WS6
    Then it sounds like its a synchro problem. If it was a clutch problem, the issue wouldn't be limited to certain gears. The synchros are probably wearing out on 3rd and 4th gears, typically it will grind if you shift faster than normal if it is in fact the synchros.
  1. 5th gear grind
    By LeadFarmer in forum Manual Transmission
    Last Post: 01-24-2012, 07:16 PM
  2. why does it grind?
    By TAallday in forum Manual Transmission
    Last Post: 10-21-2011, 05:54 PM
  3. grind into 3rd
    By mrmarcflo in forum Manual Transmission
    Last Post: 04-27-2011, 08:50 AM
  4. 1st - 2nd Grind
    By garbs in forum Manual Transmission
    Last Post: 07-20-2008, 07:28 PM
  5. 1-2/2-3 grind
    By Lextech1 in forum Manual Transmission
    Last Post: 11-08-2005, 02:20 PM
