Results 1 to 1 of 1
Thread: Noise From Rear End
07-11-2008, 07:39 AM #1Junior Member
- Omaha
Blue- 99 Z28
Noise From Rear End
99Z, mostly stock 112k miles.
Been noticing a grinding like noise from the back end. Jacked up the rear end and spun the tires. It sounded like it was coming from the pads/rotors area. The passenger side inboard pad had a small angle worn into it like it was seated wrong. Pads were original and someone suggested they could be glazed.
I swapped pads yesterday and yes, the problem is more pronounced. The wear seemed even inside to outside pad. On the inside pad there was a SMALL angle worn in the pad. Instead of being flat like this ______ it looks like this ______/. Now it's a SMALL angle and seems to coincide
with the very edge of the usable portion of the rotor. It's like the pad's just a 1/8th or 1/16th inch too close to the axle and rubbing where it should not. Everything seems right and there's no play with the caliper.
Are rear rotors different than front ones? I suspect so since I've got a spare set of front rotors on my shelf and that would be too convenient for testing purposes.
Could I be looking at a problem with the E-Brake? It works fine and stops the car (not sure how quick It should stop the car, seems a bit slow, but I didn't try a panic stop.
Suggestions?Last edited by arehm; 07-11-2008 at 07:41 AM.
rear end noise
By rickus in forum DrivetrainReplies: 14Last Post: 07-05-2010, 09:36 AM -
Rear End Noise
By nasdag in forum DrivetrainReplies: 4Last Post: 06-21-2010, 10:22 AM -
Rear end noise
By BDESHIFTER98 in forum DrivetrainReplies: 3Last Post: 10-08-2009, 04:00 AM -
Question: rear end noise
By Brad(WS/Z0.6) in forum DrivetrainReplies: 12Last Post: 02-13-2009, 12:45 PM -
Rear end noise
By 980birds in forum DrivetrainReplies: 1Last Post: 03-22-2007, 03:01 PM
