Thread: Rear End Noise
06-17-2010, 09:45 AM #1Junior Member
- Jun 2010
- switzerland
green- 99 camaro z28
Rear End Noise
Hello, I bought a 99 Z28, which has a little rear end noise , just when I lift the foot off the accelerator pedal. Just a little. What could it be ? Some serious things ?
thanks
http://www.ls1.com/forums/images/smilies/dunno.gif
06-17-2010, 12:11 PM #2
Is it at a specific speed? First what you want to do is take it past the speed where it makes noise and put it in neutral, if it makes the noise its the rear end, if it doesn't it's tranny or engine related. If it's slight it could be just loud tires and you letting your foot off the gas makes them audible. If it is the rear end the backlash is probably a bit to lose, something a mechanic could verify or you yourself could if you don't mind getting dirtym, we'll help by telling you what to look for if you go that route
06-17-2010, 12:15 PM #3None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
It's possible someone changed the rear gears. If they aren't setup properly they can make noise. Some brands of gears are known to be a little noisy as well. I'd say take it to a reputable mechanic and have it looked at. My gears do the same thing, but with the setup I have, I expected it.
06-20-2010, 12:31 AM #4
My 3.73's are a little noisier than my fctory 3.23's but even those made noise after 50k and by 70k they were junk. The rears on these are a little noisy especially if someone replaced them with richmond gears I have heard frm a few people they make a little more noise than GM or Motive gears. Can't say since I never used richmond's. But depending on mileage and the way the car was driven and if the fluid was changed can cause noise and eventually failure since the 10 bolt is junk to begin with. I wish GM would have at least used a rear like the 8.8 Mustang I never had issues with any I have owned even with h/c and a blower. This 10 bolt will break under stock power with a good enought set of tires.
1998 Trans Am 85k miles.
02 Trailblazer -Sold
09 Ram 1500 CC - Sold
09 Cobalt SS/TC - Sold
06-21-2010, 10:22 AM #5
A little gear whine is nothing to worry about.
rear end noise
By rickus in forum DrivetrainReplies: 14Last Post: 07-05-2010, 09:36 AM -
Rear end noise
By BDESHIFTER98 in forum DrivetrainReplies: 3Last Post: 10-08-2009, 04:00 AM -
Question: rear end noise
By Brad(WS/Z0.6) in forum DrivetrainReplies: 12Last Post: 02-13-2009, 12:45 PM -
Okay Okay i know im sorry another rear end noise.
By camarojunky74 in forum DrivetrainReplies: 9Last Post: 12-18-2007, 10:47 AM -
Rear end noise
By 980birds in forum DrivetrainReplies: 1Last Post: 03-22-2007, 03:01 PM
