Results 1 to 3 of 3
07-06-2008, 09:43 AM #1
Idle problem! 2 codes thrown, what to do?
Alright, I recently bought my 99 TA. Basic mods are in my sib below. LQ4 block, 6.0.
The car runs very very strong thru out the entire power band. No sluggish, misfiring, weird things going on in the performance end. I sure I am getting horrible fuel mileage. I have these two codes being thrown, but NO MIL be flashed. The codes are
http://gearchatter.com/viewtopic9948...ffed11f123b026
and , http://gearchatter.com/viewtopic9945...ffed11f123b026
Could I take this car to a nice tune/dino/shop and hopefully get it repaired? I dont understand why the MIL isnt on. I haven't figured my fuel mileage out yet, but I know it is very bad. Anyone with some information or, a nice shop to take it to around here would be great. Help me please!!Last edited by Hi-Po; 07-06-2008 at 02:45 PM.
Build in progress...
07-06-2008, 10:34 AM #2
I can post some video of car, while it is acting up. I just went back out there and started the car.... it idle at 800 RPM the whole time. In gear, out of gear. Damn I need this figured out. Checked as many connections for fuel pump as I could at the moment.
07-07-2008, 11:52 PM #3Junior Member
- Sep 2006
- illinois
black- 2001 Trans Am
Hi, On the ECM's 2 plugs. Both codes are telling you the 2 things are not getting reference volts to them. Take the 2 plugs off at the ECM & inspect them. Green corroded pin tips, or green corroded internal female connections to the pins, broken wires. Think this way, any sensor. computer sends reference volts to something. Reference volts are not normally 12V. Depending on the control. ( Coolant temp sensor, O2's, -> an unfused circut that won't blow if grounded. ) Most controls are a variable resistance thing. ECM send 5 volts to it, the resistance changes value, depending on the control. ( Think coolant temp sensor that changes resistance cold to hot. ) That 5v sent to, more or less resistance burns up electricity. Send 5V to a high resistance, the resistance burns up 2V. The ECM gets back 2V instead of the 5V sent & the program in the ECM acts on it. it also knows, thru the ECM program. No voltage sent as it didn't get any back. Reading both, you see if you get both codes you have to do the tests listed. And refer to Reference volt 1 circut, says you have a 5v reference shorting out to a voltage. Didn't say shorted to a ground. See the yes & no to the right? If you got both codes, then go to step 5. Testing for voltage at each listed step. Yes or no puts you to the next step. Dave
Codes being thrown..
By Lunatikgixxer in forum General HelpReplies: 3Last Post: 08-17-2010, 02:44 PM -
Help: Codes that are being thrown
By Lunatikgixxer in forum General HelpReplies: 10Last Post: 04-14-2010, 02:17 PM -
02 sensor codes thrown?
By GULLETT17 in forum Firebird / WS6Replies: 9Last Post: 11-12-2007, 09:54 AM -
P1641 and P1642 Codes Thrown
By 2kporter in forum LT1Replies: 2Last Post: 08-16-2007, 08:55 AM -
Intake swap and no codes thrown?
By Wheeler99WS6 in forum External EngineReplies: 1Last Post: 06-18-2007, 09:47 PM
