Results 1 to 11 of 11
Thread: Codes that are being thrown
04-12-2010, 05:42 AM #1Senior Member
- Mar 2010
- St Pete, FL
Bat mobile black- 2000 Trans am WS6 M6
My buddy that works at a shop plugged his little tester computer thing into my car yesterday to check and see which codes are popping up. Well heres a list, and i need to know what exactly to do..
ALL the o2s came up, both banks, and both sensors
P0102- Mass air flow circuit signal low
P0300- Random Cyclinder misfire
P0704- Clutch switch input CKT signal
P0803- Upshift/skip shift sol control CKT
There was another one about a reverse one but i fixed it, It was a blown fuse and it made it really hard to put into reverse.
04-12-2010, 06:06 AM #211 years of bangin gears
- Jan 2009
- North Jersey
P0102 could be a dirty MAF. Get a can of CRC MAF cleaner and spray the MAF out and reinstall.
04-12-2010, 04:30 PM #3Senior Member
- Mar 2010
- St Pete, FL
ok thank u
04-12-2010, 04:32 PM #4
Any mods or recent work done on your car?
04-12-2010, 05:36 PM #5Senior Member
- Apr 2008
- Madison, WI
All those codes are related to the same blown fuse for the Reverse lockout solenoid. The ENG SEN fuse
04-13-2010, 09:12 AM #6Senior Member
- Mar 2010
- St Pete, FL
ya i just recently got the pacesetter y pipe installed, i think that fuse is fine but ill check it/replace it
04-13-2010, 09:17 AM #7King 0f n00bz
- Jan 2006
- Shepherd, Michigan
have you got a tune...as the rear 02s are pointless know and have no spot. on top of that it is common to get the slow response time on the front 02s without going to the 1311s 02s ....however i am with cutlass on this one...swap the fuse and see if most of the codes go away.
04-13-2010, 09:19 AM #8
make sure there are no wires touching the exhaust anywhere too....might be getting a short although I would think there'd be more codes than that thrown if there was.
04-14-2010, 05:33 AM #9Senior Member
- Mar 2010
- St Pete, FL
i replaced it and theyre all still there. i havent got a tune yet i think i am getting one really soon
04-14-2010, 06:49 AM #10
04-14-2010, 02:17 PM #11Senior Member
- Mar 2010
- St Pete, FL
ok thanks man
Codes being thrown..
By Lunatikgixxer in forum General HelpReplies: 3Last Post: 08-17-2010, 02:44 PM -
Idle problem! 2 codes thrown, what to do?
By Hi-Po in forum Computer & TuningReplies: 2Last Post: 07-07-2008, 11:52 PM -
02 sensor codes thrown?
By GULLETT17 in forum Firebird / WS6Replies: 9Last Post: 11-12-2007, 09:54 AM -
P1641 and P1642 Codes Thrown
By 2kporter in forum LT1Replies: 2Last Post: 08-16-2007, 08:55 AM -
Intake swap and no codes thrown?
By Wheeler99WS6 in forum External EngineReplies: 1Last Post: 06-18-2007, 09:47 PM
