Thread: M6 Tranny Help Asap!!
07-04-2008, 03:09 PM #1Impwnded
- May 2007
- Davenport, Iowa
Bright Red- 1999 Trans Am Ws6
I got a 1999 ws6 hurst 6 speed. Anyways, I can't get into reverse. I push and push and it will not go, it feels a lot like skip shift did before I did the resistor mod. I was wondering if the reverse lock out solinoid can go bad? I've never felt a manual transmission that would not shift before so I do not know if it is like a bent fork or not. Sitting still I push and push, I hear a clunk sound like one thing pushing another, not a grind or anything just one clunk when I initially push on it. I can't get into sixth sitting still either, once I get going I can get into sixth easy though. After a lot of effort, I did get into reverse, no grinding or anything. But I've tried on five seperate occassions since and it will not go. I just spent a lot of money on something and now have a 1500 credit card bill looming over me, please tell me this isn't a horrible transmission fix I am looking at!
07-05-2008, 06:10 AM #2
Unfortunately, since 6th is involved as well, it sounds like something has failed in that extension housing area. Not an uncommon occurrence.
On the slightly plus side, if you're relatively mechanically inclined, it's a very easy transmission to work on and repair. It's a bear getting it in and out of the car, but you could save money by working on it yourself. Many of the vendors on this site that cater to the T-56 are very helpful with DIYers, since you'll be buying parts from them anyway.
Wish I had better news, but there's no magic bullet for this one.
07-05-2008, 07:08 AM #3Impwnded
- May 2007
- Davenport, Iowa
How much money if I do it myself are we talking here? As long as it is all dropped...if it is quite a bit I would upgrade to ls7 clutch and new flywheel.
07-05-2008, 11:26 AM #4Senior Member
- Jul 2005
- Jacksonville, FL
If it was the reverse lockout solenoid wouldn't it go into reverse fine, just be hard to push over to the right? If it's just hard to push over I'd check the ENG SEN fuse for the heck of it.
07-06-2008, 12:50 PM #5Impwnded
- May 2007
- Davenport, Iowa
Going to the shop on saturday...I simply don't have the capabilities to drop a tranny. I have a huge tool box and so many tools I got tools to fix tools. But I am not going to drop a tranny using jack stands. I really hope this isn't that expensive. I priced the housing at 280 dollars. Now just hope he doesn't charge me 1000 in labor. I've always done my own work, same with my dad, so I've never used a mechanic, I am just going to find myself a little self owned place and hope he is not a quak and a theif.
07-06-2008, 03:46 PM #6
It really depends on what has quit. If it's just some synchros and fork pads, it could be a couple hundred bucks. If the 6th gear issue is the 5/6 drive gear and mainshaft problem (since they are half-splined), those two pieces would run around $400. Unfortunately, you'll need to take it apart to figure out the cost.
I looked on this website and I couldn't find some of the name vendors for T56s as sponsors. If you want to know who they are, PM me and I'll send the links. They are very helpful and a lot more knowledgeable.
07-08-2008, 05:21 AM #7Member
- metro Detroit area
It could be as simple as the solenoid being unplugged. Also if they reversed the skip and reverse solenoids, neither would work right. Of course no one complains when the skip doesn't work. Simplest thing you can do is chech the fuse- it is common for these to blow and cause this.
Need a trq arm nut ASAP
By Black02LS1 in forum Western MembersReplies: 22Last Post: 05-19-2009, 06:38 PM -
Does anyone have an Auto Tranny 4L60E tranny layin around thats in good shape?
By LT1RacerMan23 in forum Parts Wanted / TradeReplies: 5Last Post: 01-28-2008, 01:48 PM -
tranny overheating, need bigger tranny cooler?
By djvaly in forum DrivetrainReplies: 22Last Post: 03-22-2007, 03:25 PM -
4L60E tranny question help asap
By hyperryder in forum Automatic TransmissionReplies: 5Last Post: 03-29-2006, 05:10 PM -
Please Help...asap Manual Tranny
By 9secondsflat in forum CorvetteReplies: 2Last Post: 01-09-2006, 03:33 PM
