Thread: 4L60E tranny question help asap
03-26-2006, 08:23 PM #1hyperryderGuest
ok heres my deal I know this is a chevy site but im very confused about some things. i own a toyota pick up im swaping the pissy engine in it for a 2003 4.3 v6 that has a 4L60e on it. i have been told that if i buy a 4.3 that has a 4L60e on it i have to use a 4l60e is this true if so why. i ask because a company call advanced adapters makes a belhousing adapter for a 4.3 to a stock toyota manual tranny and i want it but i dont want to have electrical issues. is there any thing i can do to make this as painless on my self. also i can just buy a transfer case adapter but it cost a lot of cash and i like 5 speed trannys. some one help please
03-27-2006, 07:24 PM #2Junior Member
- Mar 2006
- al
silver- 1995 s10 4.3 vortec
You don't have to use the 4l60e. The change to a manual tranny may be easer than using the 4l60e and your existing wiring harness. The rest will be up to you.
03-27-2006, 07:50 PM #3hyperryderGuestyes but i beleave i have to use the 4l60e if my computer and wire harness came with it if i just take off the tranny i was told the motor would not run right is that true
Originally Posted by kgrantkey
03-28-2006, 11:16 AM #4Junior Member
- Mar 2006
- al
Keep in mind IM just a backyard mechanic but the 4L60E shifts according to information from sensors that receive information from your engine to the transmission ECM. I don't think the engine runs from info recieved from the transmission....also the engine computer will default to a certain preset level of performance with a lack of info from some sensors, so will the tranny for that matter. Thats about as detaild as I can go.
Good luck
03-28-2006, 11:27 AM #5Junior Member
- Mar 2006
- al
If it were me and I wanted to keep my 5sp tranny I would just install the 4.3 and concentrate on getting the 4.3 to run even if I had to use some after market spark and fuel systems.
03-29-2006, 05:10 PM #6Junior Member
- Mar 2006
- Iowa
White w/ red stripes- 87 MonteCarlo SS LS1/4L60
Originally Posted by hyperryder
I'm in the process of changing my 4L60E to a t56 the harness you would get from a stock car would be setup for one or the other so you would have to change the harness to do this. Also the computer is programed to specific transmissions auto or manual. Your computer could be reprogrammed to work properly with the manual trans or you could purchase one from someone around here or ebay, (I'm not having the best of luck trying to buy another one though) The automatic trans has a big 13 pin connection into the passenger side of the tranny and the VSS. The manual has the Vehicle Speed Sensor, Reverse lockout, and Skip shift solenoid connections. If you buy a painless harness you can use it with either or, it would be just getting the computer right.
This is what I have learned with my experiences with the ls1 swap I've done.
Hope this helps some.
Josh
Help: tranny-4l60E
By blk_ss02 in forum Automatic TransmissionReplies: 1Last Post: 10-31-2008, 08:34 PM -
M6 Tranny Help Asap!!
By Smkn_TA in forum Manual TransmissionReplies: 6Last Post: 07-08-2008, 05:21 AM -
WTB 4L60E Tranny
By BlackLT1Z28 in forum Parts Wanted / TradeReplies: 2Last Post: 02-11-2008, 08:17 AM -
Does anyone have an Auto Tranny 4L60E tranny layin around thats in good shape?
By LT1RacerMan23 in forum Parts Wanted / TradeReplies: 5Last Post: 01-28-2008, 01:48 PM -
Please Help...asap Manual Tranny
By 9secondsflat in forum CorvetteReplies: 2Last Post: 01-09-2006, 03:33 PM
