Results 1 to 3 of 3
Thread: Motor surging
    Georgia
    1995 FIREBIRD
    Motor surging
    I just had to replace the water pump, distributor, plugs, wires, and fuel pump. I am geting bad surging. When you rev the engine it is like it is starving for gas. If you get in the throttle slow it doesn't act like that. All this happend after I replaced all those parts. I have also changed the tps and the map sensor, and put new o rings on the injectors. The injectors are squirting good. I have a lt1. Can anyone help me with this problem. I have been working on this for 2weeks and can't figure it out.
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Why did you replace all those parts, particularly the fuel pump? I'm guessing the water pump leaked (possiblly onto the Opti-spark dist) and while you had it apart you replaced the dist and did the tune-up as maintenance but why the fuel pump?
    Have you checked your fuel pressure?
    doylestown, Pa
    SILVER
    2004 CTS-V
    What SES light? Mileage? Need more info about the car?
  1. lean and surging only after WOT?????
    By robs98mysticZ in forum General Help
    Last Post: 10-12-2014, 09:15 AM
  2. c5 hesitation and surging
    By jamesgwinn in forum General Help
    Last Post: 08-12-2014, 07:31 AM
  3. 98 LS1 Surging
    By bwcubicle in forum Internal Engine
    Last Post: 12-11-2013, 04:00 AM
  4. Help: Why is my car surging?
    By clg82 in forum General Help
    Last Post: 08-16-2008, 04:00 AM
  5. Missing/Surging???
    By Red4Mula in forum General Help
    Last Post: 03-11-2007, 04:00 PM
