Results 1 to 20 of 33
Thread: Why is my car surging?
08-09-2008, 09:11 PM #1
Well as most of you know from my previous posts i just replaced both the front o2 sensors, then i reset the pcm by un hooking the negative battery terminal. Now while the car is ideling......sometimes the car surges between 1,000-1500 rpms....it doesn't happen all the time just at idle and not all the time..is the car just relearning the air/fuel ratio or did something F&ck up from me unplugging the battery to reset the pcm?
08-09-2008, 09:40 PM #2
drive it hard for a day or to and see if it dont get any better
08-09-2008, 10:17 PM #3
08-09-2008, 10:24 PM #4Impounded
- Oct 2007
- Beaver Dam KY
I had that surging happen a while back. Bad battery.
08-09-2008, 10:52 PM #5
08-09-2008, 10:55 PM #6Impounded
- Oct 2007
- Beaver Dam KY
Connection wouldnt matter if the battery itself was bad. Put it on a charge or find another one to throw in there fast and see what happens.
Ive posted a couple of threads about the same thing happening.. Mine did it after I left the headlights up while working on them. Just needed a good charge
08-10-2008, 02:44 AM #7
I'm pretty sure this will happen immediately, not over time
I could be wrong
Also...
I'm not the best in the world but I don't see where the battery would cause this issue. Last time I had a surging issue turned out to by a thin layer of dirt on my MAF. Try cleaning it if you haven't recently. Also I'd check the Idle Air Controller (IAC).
I don't know if this will help, but its a suggestion.
08-10-2008, 06:51 AM #8Slow'er'Ass
- Thornton, CO
You didn't reset the computer when you pulled the negative post off the battery.
You don't need to disconnect the battery to reset it.
http://www.fbody.com/tech/details.cgi?id=6
It takes about (roughly) 60-80 miles for it to relearn idle and a/f mixture.
08-10-2008, 08:10 AM #9
08-10-2008, 08:14 AM #10
08-10-2008, 08:18 AM #11O U 8 1 2
- Nov 1999
- over here...
check your bettery terminals for corrosion...
08-10-2008, 09:59 AM #12
08-11-2008, 01:50 PM #13Member
- Nov 2007
- SATX
Pewter- 2000 Trans Am
08-11-2008, 07:33 PM #14
08-12-2008, 06:02 AM #15
did you get them mixed up from front to back or left to right?
08-12-2008, 06:17 AM #16O U 8 1 2
- Nov 1999
- over here...
quick question...
do you have the rear 02's tuned off/simulators and possibly plugged the new o2 sensors in to the rear plugs???
08-12-2008, 08:23 AM #17
08-12-2008, 08:37 AM #18
08-12-2008, 08:40 AM #19Slow'er'Ass
- Thornton, CO
How many miles in the last 3 days?
Sounds like normal idle relearn to me.
08-12-2008, 08:43 AM #20
lean and surging only after WOT?????
By robs98mysticZ in forum General HelpReplies: 18Last Post: 10-12-2014, 09:15 AM -
98 LS1 Surging
By bwcubicle in forum Internal EngineReplies: 12Last Post: 12-11-2013, 04:00 AM -
Help: Surging idle
By 97ws6 in forum External EngineReplies: 10Last Post: 11-10-2010, 08:13 PM -
Help: Surging at 3500k after cam
By tep98ws6 in forum Computer & TuningReplies: 1Last Post: 01-20-2010, 08:56 AM -
All lights are surging
By bconway in forum Firebird / WS6Replies: 4Last Post: 12-07-2005, 06:01 PM
i meant the wire... and in would it be possible you connected the front o2 sensor in to the rear o2 wire...
