    sc
    2002 Z71 suburban
    160 tstat in my 02 5.3 suburban
    I have installed the 160 stat and the temp is steady at around 185 but when I turn the air on it goes to about 208.is this normal
    Quote Originally Posted by tvaughn64 View Post
    160 means it will open at 160 to start cooling instead of what ever the stocker is (probably 180)... yes that is normal for the temp to raise... your engine bumps the rpms (idle an way) up a bit to compensate for the AC pulling power away from other stuff...
    my best guess any way...
    Houston
    Grey
    2001 Silverado
    Coolants should boil around 240/255F under pressure. No engine will run 185, at least not in Houston summers. Installing a colder stat only means the system can run there if the heat transfer is balanced. 208 is quite normal for an engine. Plus, your AC condensor is in front of your radiator which raises the air temp to the radiator, which accounts for a lot of the 23F rise in coolant temperature. The rest is in the extra horsepower to run the AC.
    Jan 2008
    SOUTHERN INDIANA
    WHITE
    2000 SIERRA
    do you have to make any other changes when running a lower t-stat ?
    Member '99 SLP#24's Avatar
    Norman, Oklahoma
    1999 Camaro SS #24
    98 Corvette-99 Camaro SS
    On a vehicle with electric fans you would want to tune for the fans to come on earlier. However unless you've changed them on your Suburban you don't have e-fans so you don't need to change that.
  1. Need to replace my tstat
    By robs98mysticZ in forum General Help
    Last Post: 04-22-2011, 06:52 AM
  2. SES and a tstat?
    By zeetwentyeight in forum General Help
    Last Post: 06-27-2010, 07:06 PM
  3. For Sale: LS1 Waterpump and 160 Tstat, like new (5 hours)
    By OutToWinPAHC in forum Parts For Sale / Trade
    Last Post: 10-23-2009, 05:58 PM
  4. Question: 160 tstat
    By tvaughn64 in forum Computer & Tuning
    Last Post: 08-14-2008, 06:21 AM
  5. tstat
    By tvaughn64 in forum GM Trucks
    Last Post: 06-25-2008, 10:34 AM
