Results 1 to 10 of 10
Thread: Need to replace my tstat
04-01-2011, 02:03 PM #1Member
- Mar 2011
- Waynesboro, Pa
Mystic Teal Metallic:320c- 1998 Camaro Z/28
ok so im gonna replace my water pump, and my tstat. I dont want to do a 160 because temps year round are not steady at all. anyways i wanna put a 180 in but am not sure if i can just put the 180 in or if its like the 160 and need to get the tstat with a new housing... need to know and i have a gift card for summit so any p.#s would be much appreciated. thanks
04-01-2011, 02:48 PM #2
I would get it with the housing. I tried to pull my thermostat out of the housing and it was impossible...but I might have just been doing something wrong
04-01-2011, 05:51 PM #3
The LS1 comes with the housing and the thermostat as one unless you get the upgraded LS2 design. I have a 160 in mine and I noticed no difference. If you're fans are set to come on at stock settings then the 160 won't matter.
┌∩┐(◕_◕)┌∩┐
wouldn't want to fight them!
04-01-2011, 06:32 PM #4Senior Member
- Jan 2010
- texas
silver- 2000 formula
the 1 on summit is under the hypertech brand
04-05-2011, 05:49 AM #5
04-15-2011, 03:13 AM #6Member
- Mar 2011
- Waynesboro, Pa
ok thanks everyone
04-15-2011, 06:09 AM #7
04-22-2011, 04:56 AM #8Junior Member
- Phoenix
LMB- 2007 Z06
I put a 160 in when I moved to Albuquerque with the temps...made a real difference.
04-22-2011, 06:49 AM #9
Make sure the thermostat you purchase is "fail safe", that is to say if the thermostat fails, it fails in the open position.
SteveC
04-22-2011, 06:52 AM #10Junior Member
- Jan 2011
- pevely missouri
dark blue metallic- 2002 camaro z28
i bought a new ac/delco with a 186 degree tstat and am getting it tuned for fans to respond @ 190 degrees the stock setting for low speed fan is 226 degrees @ 190 its still 30 degees cooler to come on . i like em a little cooler alot of people set their fans to come on the same temp as the thermostat it depends as you said where you live hope this helps
SES and a tstat?
By zeetwentyeight in forum General HelpReplies: 21Last Post: 06-27-2010, 07:06 PM -
For Sale: LS1 Waterpump and 160 Tstat, like new (5 hours)
By OutToWinPAHC in forum Parts For Sale / TradeReplies: 16Last Post: 10-23-2009, 05:58 PM -
Question: 160 tstat
By tvaughn64 in forum Computer & TuningReplies: 21Last Post: 08-14-2008, 06:21 AM -
160 tstat in my 02 5.3 suburban
By tvaughn64 in forum GM TrucksReplies: 5Last Post: 06-26-2008, 06:46 AM -
tstat
By tvaughn64 in forum GM TrucksReplies: 0Last Post: 06-25-2008, 10:34 AM
