Results 1 to 10 of 10
06-21-2008, 09:33 PM #1
High Idle after APS and 317 heads install
After installing APS Twin turbo system and 317 heads I started the car up and it idles fine for a while.
When it idles for a while it starts climbing and sits around 2200 to 2400 RPM, if I shut it down and start it back up same thing.
Once it reaches operating temp, it will go to 2200 or 2400 RPM and sit there right away.
Do you think I forgot something or I need to tune for something?
I wanna drive the car to the tuneshop 19 miles away, but if I can't get it to idle normal then I'll just trailor it there.
Any Ideas guys?02 NBM WS6
APS TT LG Upgraded Snails
317's
60# Mototrons
Tuned by Sean@Solid-Technology
610RWHP
Nitrous is no more than a turbo or a supercharger wrapped up in a bottle
06-22-2008, 01:45 PM #2
06-22-2008, 03:14 PM #3Grand Imperial Wizard
- Retired Outlaw Sum Bitch
Off the top of my head....
IAC motor valve sticking
Vacuum leak
sensor connections on tps or map giving pcm bad info
06-22-2008, 03:31 PM #4Likes twisty roads
- May 2006
- England but from TX
Light Pewter Metallic- 2K Camaro Z28
Check all of your vaccum lines for loose connection or holes. Check for IAC sensor. Check MAP sensor connection.
06-22-2008, 03:41 PM #5Slow'er'Ass
- Thornton, CO
Vacuum leak, needs tuned (too much air from the turbos at idle).
What throttle body?
06-22-2008, 06:20 PM #6
06-22-2008, 08:44 PM #7
my *guess* would be incoming air from the turbo's is causing that. Frost would be able to help you more I think. My guess would be you need tuned and your idle air tables need worked.
06-24-2008, 12:14 PM #8
I tuned it rich to be safe and drove it all the way to the tuners shop like 20 miles away, upshifting like crazy to keep the RPMs down to not hit boost, and when I got there I opened the hood to show the tuner the work I had done and was explaining the High Idle issue and he looked around for like 10secs and said "Oh Shit" lol, your throttle is a bit open... Thats when I realized I had removed the adjustment cover on the throttle cable and had reapplied it too tight . I cant believe I made such a big thing out of something that I could have taken a little more time to investigate and notice the throttle was not touching the set screw.
Oh well, if thats the only thing that goes wrong for me with this buildup I will be very lucky.
Thank you for your time and patience.
Your help is always appreciated.
Filbert
06-26-2008, 06:38 AM #9Junior Member
- Apr 2006
Not sure? I know alot of blower guys need to goto ls7 TB to keep it from sucking open?
07-01-2008, 09:03 PM #10Junior Member
- Jun 2008
- ambridge,pa
red- 0235thanv
Aps
I had a vacum leak on mine, the brake booster was off on mine!!and made it ideal high
idle issues... idle high. unplugged tps runs good?
By okiels1 in forum Firebird / WS6Replies: 2Last Post: 12-31-2016, 03:36 AM -
high shift points & high idle
By Red 99 T/A in forum General HelpReplies: 5Last Post: 07-26-2010, 08:04 PM -
high idle after long tube install
By Ramairgod84 in forum General HelpReplies: 3Last Post: 10-08-2009, 09:02 PM -
By fil131 in forum Computer & TuningReplies: 10Last Post: 06-25-2008, 01:40 AM -
Heads and Cam Install finished :) Idle Video..
By juiced99ws6 in forum Almost Anything GoesReplies: 15Last Post: 06-14-2007, 10:14 AM
