    Senior Member Ramairgod84's Avatar
    Aug 2008
    peoria, az
    2001 WS6
    high idle after long tube install
    Hey all, i recently put longtubes on my car and i noticed that whenever i take the car out of gear, with the clutch pushed in, if i just let the car coast down the road, it'll idle high at around 1500 rpm. if i let the clutch out, it'll go down, or if im at a stop it'll kick down. Has anyone else experienced this?
    Member Fearls1's Avatar
    Verdigris, OK
    MRM
    2002 T/A M6
    Mine does that too. I'm pretty sure that its the speed sensor that is making sure your won't put it in a low gear with idle range rpm. Not 100% tho.
    3" MagnaFlow CatBack w/Corsa (clone)Tips, Lloyds Custom Floor Mats, SLP Lid, Pro 5.0 W/ Lou's SS, 7.5" Eaton Locker w/3.73, KYB AGX, BMR LCA's, FRA, SSE, 5% Tint, 18x9 C5 Rims w/Falken 452
    check for vacuum leaks or any unmetered air entering post maf first. Are headers your only mod?
    🤔 11s. blackbirdbrain89's Avatar
    hagerstown, mercersburg
    black trans am
    2000
    no its called throttle cracker.... u have to have it uve always had it just never noitced it so if ur bogging the car @ lets say 3rd at 25 mph and ur at 1000 rpm when u push the clutch in it wont shut off,, when ur bogging it it trying to make it idle there fore closing the IAC valve so when u press the clutch in u killed all the air and will come close to killing the eng...., ive tried to remove it so i can show off the cam but, if i do it stalls all the time and kinda sucks
  1. BBK Long-Tube Headers Install - Going Long
    Last Post: 09-09-2011, 06:30 PM
  2. Question: jet hot long tube headers install
    By Darkgoblin49 in forum External Engine
    Last Post: 04-04-2010, 03:49 PM
  3. Long tube install question
    By Jon7I2 in forum External Engine
    Last Post: 07-25-2006, 01:11 PM
  4. Will long tube install need a tune?
    By omcar17 in forum External Engine
    Last Post: 05-24-2006, 01:55 AM
