Results 1 to 13 of 13
    Member Jon7I2's Avatar
    Chicago
    99 Formula M6
    Long tube install question
    Hey guys i just wanna know if you really need to get your car up 3ft off the ground for proper intsalation of longtube headers? I went w/ dynatech and they said in the instructions min. 3ft off ground. Whta have been your experiences/ what methods to get it that high up? any help will be useful
    . thanks.
    Junior Member MCH SS's Avatar
    Ms
    Bright Red
    Yes
    Leawood, KS
    2000 Z28
    i had mine about 2 feet in the air all the way around. but i was pacesetter so yours may need to be higher
    Bragg NC
    Met. Sunset Orange
    01 SS
    Yepp unless you have a lift, The problem with my instail was the passenger side header is so dam long. The driver side went in easy but i had too get it up on ramps then about a foot or two higher then that.
    Floor jack and some pieces of 2x4 would work just fine for ya
    J
    Yup, has to be sky high. I just helped a guy put in his QTP's and the driver side on those was a bitch. We had to keep raising the car up and up because the driver header almost goes in vertical from underneath. I didn't have that problem with my pacesetters but the car was still way up there.
    I strongly recommend a good 3+ ton jack and you'll probably need a board or two to put on top of the jack to get the extra couple of inches so try to find the biggest jack you can. Sit the car on stands, slide the headers in, then drop the car to a safer height before finishing the install. I hate being under a car that high in the air.
    Member Double0me's Avatar
    FT Carson
    Blue
    1999 Blown Trans Am
    Just remember SAFTY its cheaper to get it done with the right equipment then finding yourself on a prosthetic forum.
    The One and Only ProjectCamaro.com's Avatar
    Kenosha, WI
    1999 Z28
    Up, I had to close the hood some because it was hitting the ceiling in my garage.
    Pictures Of My Camaro's
    Because You Can Never Modify To Many Camaro's
    SOM BTCH
    East Palestine, OH - USA
    SOM
    2002 Chevrolet Camaro Z28
    i only had mine 22" up
    what type of headers did you put in gillbot? with my pacesetters I was up 26 inches I think but on bababooie's QTP's the car was up way past that point.
    Lost in Texas
    Custom Slate Blue
    99 B4C
    heh, I put on mac mids in an apartment parking lot and jacking on the body (the suspension drops) my tires never got more than 2 inches off the ground
    '99 Z28 It's got the BADASS mod
    IT'S FOR SALE here:
    http://www.ls1.com/forums/showthread.php?t=70562
    SOM BTCH
    SOM
    2 sets of MACs and a couple sets of pacesetters.
    Houston, Tx
    2002 WS6 Trans Am
    Its better to plan ahead and decide how you are going to get it that high, or you are going to lose time thinking about it while your car has no headers, undriveable, and only a few inches off the ground.
    I have a SLP LT install under my belt, so I know about killing time!
    Gulfport
    2000 trans am ws6
    I used ramps, bought them from Autozone
  1. Shift kit / Long tube install
    By Guerrillakilla13 in forum General Help
    Last Post: 06-26-2012, 09:53 PM
  2. BBK Long-Tube Headers Install - Going Long
    Last Post: 09-09-2011, 06:30 PM
  3. Question: jet hot long tube headers install
    By Darkgoblin49 in forum External Engine
    Last Post: 04-04-2010, 03:49 PM
  4. SES cod PO410 after long tube install
    By raidgenz in forum External Engine
    Last Post: 06-01-2006, 02:40 AM
