Thread: Rear Diff cover
06-21-2008, 04:31 AM #1Grand Imperial Wizard
- Retired Outlaw Sum Bitch
Rear Diff cover
My 07 Silverado has the 10 bolt Eaton G80. I would like a little more fluid capacity and of course a drain plug. What covers could accomplish that and what are you guys using?
I'm thinking about this....I like the dipstick/magnet...and of course the drain plug....
http://www.mag-hytec.com/store/index...31efbaf03241bdLast edited by Sarge; 06-21-2008 at 01:56 PM.
06-21-2008, 08:44 PM #2Junior Member
- Jun 2008
- Houston
Grey- 2001 Silverado
If you like the look of the cover and you have $250 to blow, then go for it. Otherwise what does it buy you? Once the axle is properly filled, there is no need for a dipstick. The magnet, maybe, but I've pulled covers with more than 100k operating miles and never saw a need for a magnet.
Basically, there is very little wear and/or maintenance requirements for differentials. Extra fluid capacity doesn't buy you much other than it takes more to fill it. And a $250 drain plug versus a $5 gasket and 10 bolts doesn't seem like a good payout. So basically, if you like the way it looks, buy it.
06-24-2008, 09:26 AM #3
Here are some other cheaper options. . . . . . . . . . . . . . .
http://www.yourcovers.com/dc_9330_10815.shtml
http://www.partshp.com/differential_covers.htm
http://store.summitracing.com/egnsea...115+4294891994Don't be afraid of the bottle!!! Be afraid of your tune!!!
09-14-2008, 05:39 AM #4
09-14-2008, 02:14 PM #5Junior Member
- Aug 2008
- Prescott, AZ
Silver- 2004 Silverado
I've got a transdapt polished aluminum piece on my 2004 1500, I put it on when I did 4:10 rear gears. Any cover for a GM 10 bolt 8.5" ring will work.
04 gto rear diff swap to 05 06 rear diff ?
By racer00x in forum GTOReplies: 8Last Post: 11-25-2010, 07:19 PM -
Rear diff cover
By thearborbarber in forum GM TrucksReplies: 0Last Post: 02-27-2009, 02:35 PM -
RTV or Gasket For Rear End Diff Cover?
By Boat in forum DrivetrainReplies: 5Last Post: 05-21-2008, 09:08 PM -
T/A diff. cover gasket?
By Acceleration Junky in forum DrivetrainReplies: 4Last Post: 03-16-2008, 03:40 AM -
best diff fluid? good diff cover?
By ErikElvis in forum Camaro / SSReplies: 3Last Post: 03-23-2006, 08:49 PM
