Thread: T/A diff. cover gasket?
03-11-2008, 04:14 PM #1
Does the T/A diff. cover require any specific gasket other than a stock one? Any advice on creating a good seal would be appreciated also. Thanks in advance.
03-11-2008, 05:06 PM #2
It should come with one. If not I have used a felpro for a 7.5 inch 10 bolt (stock) with success
03-11-2008, 05:49 PM #3
03-15-2008, 06:05 PM #4Internet Tough Guy
- Nov 2007
- Oregon
Sinister, SixGun- 2001 SS, 2002 L36 M5
should come with one, but a stocker works fine
03-16-2008, 03:40 AM #5
Thanks again. I actually wanted to use a fel pro but wasn't sure if I should use the gasket that TA sells for it. Should I even bother with taking the cover off or should I continue to just drain, flush, and refill? The cover has been undisturbed since it's initial install 4 years ago. No leaks either.
Rear diff cover
By thearborbarber in forum GM TrucksReplies: 0Last Post: 02-27-2009, 02:35 PM -
Rear Diff cover
By Sarge in forum GM TrucksReplies: 4Last Post: 09-14-2008, 02:14 PM -
Rear Diff, Gasket?
By kool-aide in forum DrivetrainReplies: 27Last Post: 07-01-2008, 03:02 PM -
RTV or Gasket For Rear End Diff Cover?
By Boat in forum DrivetrainReplies: 5Last Post: 05-21-2008, 09:08 PM -
best diff fluid? good diff cover?
By ErikElvis in forum Camaro / SSReplies: 3Last Post: 03-23-2006, 08:49 PM
