Results 1 to 16 of 16
Thread: Timing Chain
06-20-2008, 11:23 AM #1Member
- May 2006
- Canada
Blue 1997 Trans Am(Sold)- Pewter 2001 Trans Am Vert
Timing Chain
Well its obviously a good idea to change out your timing chain during a heads/cam swap but what I'm intersted in is there any use to changing the gears aswell?
06-20-2008, 11:36 AM #2
if you get a double roller it will have new gears with it
06-20-2008, 01:07 PM #3
Always good to change wearing parts when you have the chance. If you're in there why do only half the job.
06-20-2008, 04:09 PM #4
06-20-2008, 05:14 PM #5Member
- May 2006
- Canada
so you're saying the stock gears for the timing chain only support a single roller chain rather then a double and if I get a double roller chain that it won't actually be used properly?
sorry kind of a newb and haven't seen under the timing cover of our engines yet...
06-20-2008, 05:30 PM #6
the double roller has 2 chains, therefore it needs 2 gears on each shaft. they arent a picnic though. ive read that you have to do a little minor machining to some of them to get them to fit. i just got the ls2 timing chain for mine. i spin up to 6800 before i shift
06-20-2008, 08:10 PM #7
I just did the chain only. My gears looked fine.
06-21-2008, 09:18 AM #815 sec. Oh yeah, its fast
- Apr 2007
- Forest Lake, MN
maroon- 2000 Z28
Stick with the single chain LS2. I spin over 6800 as well and have no problems. Plus, it can be a bitch to get the timing cover to fit with the double roller. I don't think it's worth the headache. If the car has over 60,000 miles on it, go ahead and change out the gears while your at it.
06-22-2008, 02:57 PM #9Member
- May 2006
- Canada
alright thanks guys I appreciate it
07-01-2008, 03:43 AM #10Junior Member
- Ca
LS2 chain is all you need
07-01-2008, 05:49 PM #11
my dealer tells me that the chain does not need to be replaced unless its broken. are they full of it?
07-02-2008, 12:44 AM #12
07-02-2008, 05:08 AM #13
chain
I was going to change it as part of routine maintance.
07-02-2008, 08:17 AM #14
No. On your average car with a timing chain, it never needs to be serviced unless it develops excessive slack or it breaks, both of which are pretty uncommon.
However, our engines are high performance and are subject to high RPM's, and therefore more likely to stretch or break, so changing the timing chain while you are in there is good idea.
07-02-2008, 11:11 AM #15
07-02-2008, 01:59 PM #16
I would always change the gears with the chain. If you have ever had a dirt bike or chain driven atv you would know why
timing chain
By RedHot99T/A in forum External EngineReplies: 7Last Post: 01-31-2011, 02:58 AM -
For Sale: Timing Chain Set
By Dillard99 in forum Parts For Sale / TradeReplies: 0Last Post: 06-25-2008, 09:35 AM -
LS2 Timing chain set
By sammy burks in forum Parts For Sale / TradeReplies: 6Last Post: 03-24-2008, 11:02 AM -
Ls1 timing cover, Dual row timing chain
By xssive in forum Parts For Sale / TradeReplies: 0Last Post: 08-06-2007, 06:41 PM -
timing Chain
By 2001bird in forum Internal EngineReplies: 7Last Post: 11-14-2006, 05:15 PM
