Thread: timing chain
01-30-2011, 05:47 AM #1
timing chain
Now I'm doing h/c/I and looking for timing sets,I heard an ls2 will work but don't know anything about that,I was looking at a adj.ls1 timing chain,or should I just buy a new oem timing set,I'm confused about this,lemme kno what you all think I should do.
01-30-2011, 07:37 AM #2Sold: LS1 '85 El Camino
- Dec 2005
- Laurel, Maryland
When I did my H/C/I Swap, I went with a double timing chain and love it. Obviously, it came with new gears to accommodate the two chains. Others swear upon the Katech C5R Chain. It uses the stock gears since it's a single chain. If I was to do it over again, I would use the Katech Chain, since you won't have to remove the gear from the crankshaft (which is a bitch).
Also, this belongs in the Internal Engine Section.
01-30-2011, 07:44 AM #3
Ok yea I don't wanna go thru that,thanks and o...wasn't paying attention thanks
01-30-2011, 09:31 AM #4
The LS2 timing chain is also good
01-30-2011, 10:58 AM #5
LS2 timing chain is the budget way to go
01-30-2011, 06:39 PM #6Sold: LS1 '85 El Camino
- Dec 2005
- Laurel, Maryland
I would never go "budget" on something as important as a timing chain. You snap a timing chain and bye bye motor.
01-30-2011, 07:40 PM #7
its the cheaper of the options, still good quality
01-31-2011, 02:58 AM #8
I used a Trick flow double roller w/2 deg adjustments..As for the Crk shaft gear ..A 3 jaw puller works great w/ the crk bolt in all the way..so not damage the crk when pulling...U can rent them from an auto store.
Wanted: WTB New LS2 Timing chain set
By blackSS01 in forum Parts Wanted / TradeReplies: 0Last Post: 05-05-2009, 08:11 AM -
For Sale: Timing Chain Set
By Dillard99 in forum Parts For Sale / TradeReplies: 0Last Post: 06-25-2008, 09:35 AM -
By sammy burks in forum Parts For Sale / TradeReplies: 6Last Post: 03-24-2008, 11:02 AM -
Ls1 timing cover, Dual row timing chain
By xssive in forum Parts For Sale / TradeReplies: 0Last Post: 08-06-2007, 06:41 PM -
timing Chain
By 2001bird in forum Internal EngineReplies: 7Last Post: 11-14-2006, 05:15 PM
