    98 trans am
    need obd2 help please
    I have a 98 transam and my girlfriend has a 99 transam and the obd2 port doesnt work on either car!! I plugged my code reader (which has worked in the past on both cars) and it doesnt work anymore. i also tryed my hypertech programmer on my 98 and nothing there either has anyone had this problem or could you point me in the right direction. i called gm and they said my computer is burt up and i need to purchase a new one from them! i am seriously dreading buying two computers!!
    Dawson, IL
    2000 Trans Am
    Check the CIG/ACCY fuse on them - could just try the Cig lighter - they(OBD port & cig lighter) are on the same fuse
    Senior Member
    Jacksonville, FL
    Welcome to the board. Do the cigarette lighters work? Check the fuse labeled CIG/ACCY in each car, that circuit powers the DLC port.
    Colorado Springs
    94 Trans Am
    Anybody suggest a code reader for a 94 Trans Am? I have the older ODB2 port, the rectangular one with the notch on top. I bought a code reader that fits, but it doesn't seem to work. Then I had the guys at the store hook up a more modern version and it wouldn't even come on.
    At first I thought fuse too, but my Hypertech works fine.
    I figure there must be a very specific reader out there for the older cars with the first versions of ODB2 on them. The reader I have only has 3 pins and it seems one of the pins doesn't connect to anything in the block.
    Any suggestions?
    Oh, after doing some research, it seems I may have an ODB2 port but have an ODB1 computer - in a hybrid called ODB1.5.
    now how to get the code out!
    Ok, after more research there is one recommended one for about 150 dollars on ebay.
    ACTRON 9150 SUPER AutoScanner Kit OBD I & II CP9150 NR
    98 trans am
    sorry for such a late response but i didnt have access to the cars. The cig lighter fuse was blown and when i changed it the port worked. Thanks for the help guys
  1. OBD2 scanners
    By pewterz55 in forum Tools
    Last Post: 01-19-2012, 06:41 PM
  2. OBD2 Codes -- Where to start
    By SilentTrouble in forum Computer & Tuning
    Last Post: 03-09-2008, 03:21 PM
  3. Need Help With Obd2
    By SWEETZ in forum General Help
    Last Post: 08-28-2007, 06:25 AM
  4. Tunercat OBD2
    By foff667 in forum Parts For Sale / Trade
    Last Post: 08-22-2006, 04:36 AM
