    IOWA
    WHITE
    1999 CAMARO Z-28
    Need Help With Obd2
    Do U Have To Have A Special Scanner To Read Camaros Cause Ive Tried 2 Different Ones And They Keep Saying Must Plug Into Car. It Threw A Check Engine Light. Any Info Would Be Appreciated
    Senior Member
    Jacksonville, FL
    What scanner you trying to use? See if the CIG/ACCY fuse is blown, most handhelds w/o battery power won't even power up with it blown because the connector gets power from that circuit. Also make sure the key is in the ON position.
    IOWA
    WHITE
    1999 CAMARO Z-28
    It Doesnt Work So I Will Check That Fuse Thanks So Much
    Baumholder, Germany
    Green
    94 Camaro 3.4
    I agree with what he said, and if that doesn't do it, then the connector itself might be damaged, because the regular scanner should work.
  1. OBD2 scanners
    By pewterz55 in forum Tools
    Last Post: 01-19-2012, 06:41 PM
  2. need obd2 help please
    By brownie98 in forum Computer & Tuning
    Last Post: 07-12-2008, 07:44 PM
  3. OBD2 Codes -- Where to start
    By SilentTrouble in forum Computer & Tuning
    Last Post: 03-09-2008, 03:21 PM
  4. Tunercat OBD2
    By foff667 in forum Parts For Sale / Trade
    Last Post: 08-22-2006, 04:36 AM
