Thread: Fan setting
06-18-2008, 03:40 PM #1
Fan setting
I just installed a 180 degree thermostat in my camaro. What would be appropriate fan setting for both the low and high speed fans?
06-19-2008, 05:53 AM #2Senior Member
- Jul 2005
- Jacksonville, FL
Assume you're changing them yourself, try these and if you feel they're running too much for you raise them a little:
Fan 1 on/off 194/183
Fan 2 on/off 204/195
06-19-2008, 02:23 PM #3
I'll give them a try. Thanks
06-19-2008, 02:34 PM #4Senior Member
- Jul 2005
- Jacksonville, FL
With a 160/FTRA and here in Florida mine are set at 184/175 and 194/185 - thinking of changing mine to the same thing...they run all the time in the heat...going to see if it really makes any difference. Those settings are from an old post from James at RWTD.
06-19-2008, 07:39 PM #5
I tried the setting and my fans ran all the time. I did some data logging with the fans off and found my car runs at 194 degrees with the AC on and 90 degrees outside. I figured that was about as hot as the engine would get under normal driving. I added 10 degrees to allow for fluctuations in temp. I then used a 7 degree temp spread life the factory tune and went from there. I tested it out in stop and go traffic and them only got to 204 ish. The fans only came on when jammed up at a long light and the temp dropped quick. The high speed fans never came on. Then once I got on the freeway the temp dropped back to the 194 area again.
06-20-2008, 06:18 AM #6
Question: What is your setting?
By 35th-ANV-SS in forum Suspension and HandlingReplies: 9Last Post: 07-15-2010, 10:28 AM -
What setting should I have it too?
By JwMonE99 in forum Suspension and HandlingReplies: 3Last Post: 09-04-2009, 01:06 PM -
Setting up my 9 Inch
By MrClay02ws6 in forum DrivetrainReplies: 3Last Post: 06-17-2008, 03:35 PM -
Setting Backlash
By 98formy in forum DrivetrainReplies: 0Last Post: 08-22-2007, 06:43 AM -
Setting up my NOS
By Txyoungguns in forum NitrousReplies: 15Last Post: 01-28-2007, 11:02 AM
