Results 1 to 16 of 16
    Daingerfield
    2000 Z28
    Setting up my NOS
    My Nos says to run colder plugs and to back my timeing off for my bigger shots. I have a 2000 Z28 but I can not info on plugs temps and numbers and I have a DiabloSport Predator programer but no one can tell me what% to back off my timming a WOT am all ears guys.
    Aug 2000
    Indy
    1 degree per 100 shot
    Car RamRod 98Camarod's Avatar
    Feb 2006
    Goose Creek, SC/ NWS
    Green
    1998
    Autolite 103's, NGK TR6's, these plugs are colder than stock. You can get a timing tuner to take the timing out only when the nitrous is activated. This is so it does not interfere with the n/a tune.
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Quote Originally Posted by Txyoungguns View Post
    How much do you plan on spraying......? Also what fuel pump and are you running a adj. regulator or is it all stock...?
    If it's a wet kit you can get away with a 100 all day with "stock" timing....... If you have the Diablo tune it already advanced your timing so be carefull there!!!
    Daingerfield
    2000 Z28
    NOS Tuning
    I am running a stock fuel pump. I have changed the timing back at WOT by what it says 2%. Running jets 34 fuel and 54 N2O for a 125 shot.
    Michigan
    99 camaro
    Quote Originally Posted by 98Camarod View Post
    I agree with the timing tuner, I love mine, very easy to install and works like a charm.
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    2% is alot for only 125 shot......Let's say it had 38* total that means your pulling 7.6* out which is way more than you need to!!! 1% would be fine. You don't know what your fuel pressures at....?
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    Quote Originally Posted by LS2Tuner View Post
    maybe my math is off, but 2% is only .76*. 20% is 7.6*
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Your right....... I was thinking 20% in my head all the early Predators I used were 10%,15%,& 20% ect. for timing adjustments.
    But it has been years since I used one on a pcm that old they are good with coming up with updates to download from there site.
    trafficKING sobaka79's Avatar
    mississippi
    '99 T/A
    i dont know anything about timing tuners, can you give me a suggestion or point me in the right direction? i have a tune that i want to keep except under nos
    Feb 2006
    Green
    1998
    Harris Speed Works sells them, on their site go to Nitrous controllers, and pick window switches and timing tuners, they are $250. Many places sell them, but HSW has top notch customer service.
    Daingerfield
    2000 Z28
    So if I am reading this right my stock timeing is 38* and I need to get 2* @WOT reterted. So what % do I need to back off my timing my math really sucks. I have steped up to a high flow fuel pump w/pressure guage in a piller pod.
    orlando, fl
    2014 camaro 2ss/rs
    38* x 5% (.05) = 1.9* so, in your handheld select -5%.
    STL,MO
    Quote Originally Posted by andy670ho View Post
    where can you get it? I havent been able to find one
    Feb 2006
    Green
    1998
    Harris Speed Works has one.
    SoCal
    Mag Red
    '98 C5
    You can also try to use iridium plugs, work like a charm
  1. Question: What is your setting?
    By 35th-ANV-SS in forum Suspension and Handling
    Last Post: 07-15-2010, 10:28 AM
  2. What setting should I have it too?
    By JwMonE99 in forum Suspension and Handling
    Last Post: 09-04-2009, 01:06 PM
  3. Fan setting
    By thearborbarber in forum Computer & Tuning
    Last Post: 06-20-2008, 06:18 AM
  4. Setting up my 9 Inch
    By MrClay02ws6 in forum Drivetrain
    Last Post: 06-17-2008, 03:35 PM
  5. Setting Backlash
    By 98formy in forum Drivetrain
    Last Post: 08-22-2007, 06:43 AM
