Page 1 of 3 123 LastLast
Results 1 to 20 of 43
    Senior Member GottaHaveLS1's Avatar
    Connecticut
    1999 Trans Am M6
    Fuel Pump: drop tank or make access panel?
    I've been having fuel issues and my tuner can't tune my car to it's potential until i get more fuel. So i'm going to swap the fuel pump and probably the fuel filter again just in case. I don't know if there is much more i can do. is it easier to take out the back seat and cut through the metal to access it from the top or should i just drop the tank? is there a write up on how to make an access point for the fuel pump?
    DROP THE TANK!!!!
    No other way to do it.
    While it is down, clean it up. Worth the extra hour.
    Lowered, HID's, tinted.
    Connecticut
    1999 Trans Am M6
    i just found a write up on ls1tech that tells you how to cut the metal above the tank. my dad and i think it will be easier. we will still empty the tank as much as possible and we have a very powerful air compressor to blow out any sediment.
    if i were to take it out, how do you recommend cleaning it?
    Member Bouvers's Avatar
    Blue 1997 Trans Am(Sold)
    Pewter 2001 Trans Am Vert
    no argument sorry Luos... may an access port, if you do it properly its not bad at all and then you can re-access your fuel pump in very little time if something goes wrong again... much better decission...
    no one will ever know its there... much better decission... if the day comes for my car I know exactly which course I'm taking...
    Quote Originally Posted by GottaHaveLS1 View Post
    With water.
    It is plastic tank.
    DO NOT CUT YOUR BODY UP!
    Connecticut
    1999 Trans Am M6
    hmmm, my dad didn't recommend using water... to each his own i guess. i know what you mean about cutting it up... but my car is nothing special especially since i just past 72K! i like the idea of making an access door so it's much easier next time. my friend said his prelude came with one from the factory as most cars do. but as you all know, GM doesn't keep convenience in mind
    here
    2001
    i cut the hole.......it was a very fast way to get it done.....i made a cover for the hole at work and screwed it down.......bingo done 1.5 hrs total
    That part of the car is support. No way would I cut it.
    I cleaned out my tank with water. Dried it out, and then let it sit for a few hours upside down.
    Once the 'bucket' the pump is in is removed, the tank is nothing but plastic.
    Just because something is easier, doesn't make it the right way to do it.
    here
    2001
    true...but it does make it easier.........
    Member squee's Avatar
    Baton Rouge
    2000 SS M6
    I'd have to agree with Luos. I would NEVER EVER cut a hole just to make it a little easier...
    here
    2001
    Quote Originally Posted by squee View Post
    not a little....a gang easier
    DROP THE TANK!!!!
    i agree...
    Connecticut
    1999 Trans Am M6
    i just hate how most other cars have these trap doors stock. i also don't need as much support as Mr. Luos does with 531 rwhp. I won't have numbers like that for years! my dad is also great with doing things like this and he'll probably figure something out to keep the structural integrity.
    Ever stop and think about why ours don't???
    Could it be that there wasn't a safe way? Or just GM being lazy? Or a little of both?
    here
    2001
    sub frame connectors.....weld in
    here
    2001
    you should make a poll on this...... a=lazy b=safety
    I think the support is more side to side.
    I am too lazy.
    here
    2001
    I am too lazy.
    now thats a safe answer........
    here
    2001
    I am too lazy.
    not twist?
    not twist?
    That too.
    Not really thinking much at this time of the day.
  1. possible to use a 99-02 Fuel pump in a 98 tank??
    By mike171562 in forum External Engine
    Last Post: 02-01-2011, 11:42 AM
  2. can't drop my 98 fuel tank!!
    By JayTA98 in forum General Help
    Last Post: 04-17-2010, 04:40 PM
  3. Patch Panel for Fuel Pump Install
    By John Junkins in forum Parts Wanted / Trade
    Last Post: 02-20-2008, 04:10 PM
  4. Replies: 10
    Last Post: 01-14-2008, 08:57 PM
  5. F/S: 255 LPH in tank fuel pump
    By nevrlift in forum Western Members
    Last Post: 09-11-2007, 02:22 PM
