Results 1 to 11 of 11
01-12-2008, 09:18 AM #1Senior Member
- Lexingon Kentucky
1997 Grand Cherokee- 1999 Firebird.
My fuel pump is broken. Any way to make it work just ONCE?
I need to start my car to drive it to the shop but the fuel pump has been broken for a while. It cranks strong but won't turn over. Is there any way to start this damn thing just one more time??? Bang on the gas tank with a sledgehammer or pee in the center console? I don't want to pay for another tow.
01-12-2008, 09:22 AM #2
no tow on your insurance I take it ?
01-12-2008, 09:38 AM #3
if banging on the tank with a hammer doesnt work. u can try to spray a little starter fluid in the throttle body but be very careful with that
01-12-2008, 09:41 AM #4
peeing on the center console can get dangerous
01-13-2008, 11:02 AM #5Senior Member
- Lexingon Kentucky
I beat the shit out of the fuel tank with a 4lb mini sledge but that got me nowhere. I used the started fluid and that worked like a charm. It only ran for a few seconds though. Soooo....I had my wife start the car after I sprayed the TB and kept spraying a little everytime it started to die. I quit after the smoke alarms went off
Still nothing. Thanks for the help everyone.
01-13-2008, 05:15 PM #6
The fuel pump on my van went out and I was stranded on the road about a block from the shop. I called my buddy back at the shop and told him what happened and could he rescue me. Well, he showed up with 2 cans of carb cleaner, popped open the hood and pulled the air filter out. He stood on the bumper, held on with one hand and sprayed with the other. I started the van, threw it in gear and motored back to the shop. Maybe not the safest thing to do but it worked.
01-13-2008, 08:19 PM #7
im assuming your van was a carb though
01-13-2008, 09:32 PM #8
I guess your wife is going to have to sit in the engine bay, keeping on the starter fluid while you drive it to the shop.
01-14-2008, 02:32 PM #9
You don't want to get to crazed with the starting fluid, not good for motor.
01-14-2008, 05:44 PM #10
01-14-2008, 08:57 PM #11
will fuel pump off firebird work on my ss?
By khickenwang in forum Camaro / SSReplies: 1Last Post: 03-31-2010, 04:46 AM -
Fuel Gauge Broken?
By Neo in forum General HelpReplies: 6Last Post: 10-19-2009, 11:51 AM -
What do I need to make this crate work?
By MachWon in forum CorvetteReplies: 3Last Post: 09-27-2009, 08:04 AM -
Fuel Pump: drop tank or make access panel?
By GottaHaveLS1 in forum General HelpReplies: 42Last Post: 08-27-2008, 07:42 PM -
what Make Oil Pump would you use
By FuzzyMcGee in forum Internal EngineReplies: 13Last Post: 02-28-2007, 11:15 AM
