Results 1 to 3 of 3
Thread: Rear End Rebuild Advice
06-17-2008, 06:42 AM #1
I'm about to install some new gears in the rear end of my Trans Am (yeah, I know. "get a 9 inch," etc.), and I need some advice on a problem I've had in the past. Yes, I'm aware that this is probably a pretty silly question.
On two other 10-bolt installs I've done (different cars), I've had a problem with the cross-shaft bolt. In both cases, the bolt has worked itself loose, and the rear end grenaded. In the first case, I torqued it pretty hard, by feel (came loose within a day). The second install, I torqued it to GM service manual specs (came loose after 30,000 miles).
Both installs worked without a problem, except for that damn bolt. Now that I'm about to do the install on my Trans Am, I'm just a little afraid of the same problem. Are there any tricks I'm missing, to ensure that the one stupid bolt that holds the entire thing together stays in place?
06-17-2008, 07:05 AM #2King 0f n00bz
- Jan 2006
- Shepherd, Michigan
sorry i have no idea..but i'll bump this thread up to the top for you
06-17-2008, 07:25 AM #3Senior Member
- Sep 2007
- Denton, Texas soon Lafayette, Louisiana
Blue- 2002 Z28 Camaro M6
I doubt this is any wonderful trick that is guaranteed to work, but maybe try some locktite.
Need some advice. Rebuild or save for replacement?
By Nero.Jacinth in forum General HelpReplies: 4Last Post: 05-13-2009, 08:31 PM -
advice on engine rebuild
By tk66k in forum GM TrucksReplies: 10Last Post: 02-04-2008, 05:50 PM -
Need to replace/rebuild LS1 99 WS6 Need Advice!!!
By belairtx55 in forum Internal EngineReplies: 47Last Post: 10-04-2007, 12:55 AM -
Need Expert Advice On Engine Rebuild...
By dferg99 in forum Internal EngineReplies: 8Last Post: 11-09-2005, 01:38 PM -
Need Advice On Engine Rebuild
By 1992B4C in forum Internal EngineReplies: 3Last Post: 10-15-2005, 05:09 PM
