Thread: Need Advice On Engine Rebuild
10-15-2005, 02:31 PM #1Junior Member
- Oct 2005
- Arizona
black & white- 1992 Camaro B4C
Gang, I am obviously new to the LS1 arena and here is what I need help in. I might be purchasing a 2002 police camaro with a blown motor. Actually, something cracked the oil pan and he continued the chase and seized the motor i guess.
My questions are; anything salvagable in this engine. I know we wont really be able to tell until a teardown but maybe someone here has experienced it.
Question 2; if the bottom end is junk, what is normally advisable and cost effective for a short block
Question 3; what about heads & cam(while it is down, I have no problem with extra horses(400+ sounds good) except cost will become a factor eventually)
Question 4; what are the nominal labor charges for doing an engine R&R. Guessing a couple grand. Is it something I might be able to do in my garage(dont know if I can raise the car high enough to drop cradle and engine.
Any help is greatly appreciated.
10-15-2005, 03:34 PM #2
um i have a shop rebuilding my engine, and the labor is $1,500
and im having a cam and new intake installed oh and stall and headers.
10-15-2005, 04:51 PM #3Grand Imperial Wizard
- Retired Outlaw Sum Bitch
No way would I put a penny into this motor...no way no how....
Originally Posted by 1992B4C
Cylinders/bearings/valves/crank... etc. where does it end?...get a crate motor for under $3500 and go like hell....
10-15-2005, 05:09 PM #4Junior Member
- Oct 2005
- Arizona
Thanks for the reply's, but where can you get a crate motor for $3500? Is that short block only I am guessing. Like I say, I am a noob so any insight is appreciated. Thanks again.
Need some advice. Rebuild or save for replacement?
By Nero.Jacinth in forum General HelpReplies: 4Last Post: 05-13-2009, 08:31 PM -
Rear End Rebuild Advice
By jcws6 in forum DrivetrainReplies: 2Last Post: 06-17-2008, 07:25 AM -
advice on engine rebuild
By tk66k in forum GM TrucksReplies: 10Last Post: 02-04-2008, 05:50 PM -
Need to replace/rebuild LS1 99 WS6 Need Advice!!!
By belairtx55 in forum Internal EngineReplies: 47Last Post: 10-04-2007, 12:55 AM -
Need Expert Advice On Engine Rebuild...
By dferg99 in forum Internal EngineReplies: 8Last Post: 11-09-2005, 01:38 PM
