    Dec 2004
    SS: NBM, tan top
    1998-SS, 2010 Jetta TDI
    Exclamation High voltage O2 sensor Circuit
    I keep throwing codes for high voltage bank 1 and bank 2 rear O2 sensors , i have removed the cats, with an ORY and O2 Simms, are my simms going bad and causing these codes, the simms have worked great for about a year with no problems,
    also if i erase the code it doesn't come back on until another 50 miles or so, please help
    thanks,
    Jeff
    98' SS Convertible Camaro-76k-Build # 1471, Cragar SS rims, RK SFC's, MAC Panhard, LSX Tune, Shaner S3,
    SLP:short thro,Strut tower brace,fan switch
    MTI Power induction kit,40 Series muffler,Pacesetter LT's + ORY,12 CD changer,3800lbs
    http://www.cardomain.com/ride/787506/1
    Sims are probably bad like you mentioned. Just get the codes tuned out.
    Painted manta stripe
    Dec 2004
    SS: NBM, tan top
    do u think the car runs any different if the SES light is on for those codes, ie if the SES light comes on again will the car perform any worse if i just stop erasing them at autozone?
    Quote Originally Posted by ss~zoso~ss View Post
    If the codes are for those rear 02s, it won't make the car run poorly if the SES light is on. The only reason to get the light itself turned off at autozone is because its annoying you.
  1. P0343 DTC P0343 Camshaft Position (CMP) Sensor Circuit High
    By Camaro98Z/28 in forum General Help
    Last Post: 10-16-2013, 07:57 AM
  2. P0327-Knock Sensor Circuit Low Voltage
    By 1slowbusa in forum Computer & Tuning
    Last Post: 03-25-2013, 10:16 PM
  3. circuit 2 sensor 2?
    By pk222 in forum General Help
    Last Post: 12-21-2009, 09:33 AM
  4. PO343 Cam Position Sensor Voltage High.
    By 24v in forum Computer & Tuning
    Last Post: 02-14-2007, 04:34 AM
  5. O2 sensor voltage
    By speedkills in forum Computer & Tuning
    Last Post: 12-30-2006, 08:54 AM
